Old 05-04-2007, 02:05 AM   #1
rapo71
rapo71's Avatar
Front solid axle flip
Has anyone ever tried putting a solid front axle on top of the leaf springs?
thanks
rapo71 is offline   Reply With Quote
Old 05-05-2007, 12:29 AM   #2
nvrforgotten52
nvrforgotten52's Avatar
Re: Front solid axle flip
yeah me and my friend just did that and it is sick. it dropped the front end six + inches. and it clears everything including the stock steering arms and v8 oil pan.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-05-2007, 12:35 AM   #3
rapo71
rapo71's Avatar
here is one picture of it just bolted in real quick. i will post more later. thanks
Old 05-05-2007, 02:45 AM   #4
Daniel U
Daniel U's Avatar
Welcome to the board! Your about 45 min. from me. My brother's going to do somthing similar to his '50 GMC. Are you going to the Paso show Memorial Day weekend? Always neat to find another local CA. Chevy truck enthusiast.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 05-05-2007, 06:41 PM   #5
rapo71
rapo71's Avatar
Hey Daniel U, I like the work you've been doing on your '54. I'm thinking about going to the Paso show, I just got back from the Morro Bay show actually. Anyway, talk to you later.
52 chevy 3100 in progress with 350/700r4 combo coming soon.
71 C10 SWB 305ci 3spd manual
Old 05-06-2007, 11:21 PM   #6
Daniel U
Daniel U's Avatar
Thanks for the compliment. I missed the Morro Bay show. I had some stuff at home and work that "trumped" my attendance at the show. What are your plans for the truck? This forum is great for ?'s and ideas.
Old 05-08-2007, 12:19 PM   #7
Riggs'57
Did you weld a plate on the bottom of the axle? Does the truck bumpsteer like crazy...looks like a death trap. If it works well, I'll do it to my 57 though!
'57 GMC 150
'72 440 Charger
Looking for 4 banger commuter car for college
(440 isn't good on gas....) <$2500
Selling '57 GMC 3/4 ton, new brakes, runs/drives $1000
Riggs'57 is offline   Reply With Quote
Old 05-08-2007, 09:19 PM   #8
rapo71
rapo71's Avatar
I didn't weld a plate on the bottom, the truck isn't running so I'm not sure how rides. The way it's set up is temporary. I did it to see what the clearances are like and how much it would drop the truck
Its basically a free 5-6 inch drop. It has about as much clearance from the frame to the axle as monoleaf springs would have.
Here are some pictures with the fenders on it.
Here's a 57 chevy with monoleafs:
Old 05-09-2007, 04:37 PM   #9
nvrforgotten52
that is just plain sick. very nice
Old 03-30-2009, 07:06 PM   #10
c0rey
Any updates on this? Im intersted we are running the stock 3.5 engine so everything should clear.
c0rey is offline   Reply With Quote
Old 03-30-2009, 07:24 PM   #11
mr48chev
mr48chev's Avatar
To do it right you would have to reverse the spring bolts so that the end the axle sat on was on top. Then you would have to drill a matching locating hole in the bottom side of the axle and I would make a spacer that fit on each side of the axle front and back that the U bolts went through when you bolt it back together. It will most likely take new U bolts because I think the old ones will be way too short.
I can't speculate on the bump steer thing but my guess is that it will be a handful to drive on all but the best roads.
I pulled leaves out of my springs years ago (1989 to be exact) because I was throwing the truck back together to make it to a Kustom Kemps run in Centralia Wa that September. The plan was to go to the run and then take the truck back apart and do things right. 20 years later I am getting around to doing things right. On my truck the way it is setup there is no relaxing when driving down all but the smoothest freeways as you constantly have to be ready for what it does next. That is the main reason that I am swapping back to an independent front end in this rebuild.
Old 04-27-2010, 02:07 AM   #12
rapo71
rapo71's Avatar
Wow, I haven't posted anything in 3 years haha! That means 3 years worth of progress pictures...
Old 04-27-2010, 02:10 AM   #13
rapo71
rapo71's Avatar
a few more...
Old 04-27-2010, 02:15 AM   #14
rapo71
rapo71's Avatar
the cab
Old 04-27-2010, 09:52 AM   #15
mr48chev
mr48chev's Avatar
Looks like you have been pretty busy in the past (wow that long) three years. Trucks looking good.
Old 04-27-2010, 08:09 PM   #16
NONHOG
NONHOG's Avatar
So the question remains...........Did it ever work out or did you go IFS and forget it ?
I have only seen the one here.... V.... from the HAMB link.
http://67-72chevytrucks.com/vboard/s...d.php?t=397448
I'll likely go drop axle however I've heard rumor of drop spindles coming out.
Still curious about this flip possibility.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 04-27-2010, 11:39 PM   #17
rapo71
rapo71's Avatar
No, I actually went with the Ifs with air bags. Haha. I have pictures of the frame above. I wanted to go with disc brakes, It didn't seem worth it to mess with the solid axle.
Old 04-27-2010, 11:55 PM   #18
NONHOG
NONHOG's Avatar
Was hoping you ran the flip before the IFS install. Oh well you have a cool truck either way !
Old 04-28-2010, 01:43 AM   #19
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Local People, Wa-Hoo..... Anyways on to the subject at hand. From my experience in the off road world flipping the axle would not work because:
A) Does not center itself on the springs (Can be modified though).
B) Way to much load on your poor springs. That much leverage against your springs will start axle wrap on the front (way bad).
C) It'll "S" shape the springs, put way too much load on all the bushings, and every time you hit a bump the front end will get away from you.
Also, if you do this make sure you don't put your thumb inside the steering wheel.... When you hit a bump, and the axle wraps it will throw off your steering geometry and rickshaw back through the steering wheel making it spin hard and with no warning causing you to lose your thumb from the spokes of the steering wheel.
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 04-28-2010, 01:49 AM   #20
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
You do realize they are doing the opposite of what you speak?
These guys are flipping the stock axle to the TOP of the spring to lower the truck, not BELOW it to raise the truck as is commonly done in the offroad world. Since these are 2wd trucks, wrap is not an issue, but having the axle above the springs reduces wrap anyway.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-28-2010, 10:36 AM   #21
addicted2dunes
Yes, I understand it, they are lowering the truck. Axle wrap is still an issue. The further you move the spindle from the spring, and having it mounted to the spring on the same side as the spindle = Axle wrap.
Also, I have never seen, "not BELOW it to raise the truck as is commonly done in the offroad world." That is way bad.
Cameron Gunlock
Old 04-28-2010, 11:48 AM   #22
Dan Bowles
AD Addict
Really? Look at most of the CJ5s and 7s that are running anything substantial for tires and you'll see that quite a few are running the leaves above the axles. I gained an easy 6" so I could run my 39.5" Super Swampers in college. All I had to do was change the angles a bit and lower my trans to keep my steering geometry working. I didn't use blocks, THAT is way bad (on the front!)
Axle wrap on a dead axle won't be as severe as the only input will be the bump in the road, not a powered tire adding torque. But really, what would the difference be on a straight axle if it were mounted above or below the spring? If the distance is the same, the torque arm is still the same. Is it not? It just boils down to mounting it the same!
Dan Bowles is offline   Reply With Quote
Old 04-28-2010, 01:57 PM   #23
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
The length of the arm changes by about the height of the axle cross section at the mounts, and in the case of one of these trucks that is a couple of inches. I've seen axle flips that looked intriguing but never saw one that looked safe on what appeared to be a running driving truck.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 04-28-2010, 08:24 PM   #24
addicted2dunes
I know about Jeeps..... that's what I build..... That is called SUA (Spring under axle), completely different then these era trucks! A driving axle (like you say, Jeep) is a straight axle housing. These era trucks run dropped axles already (ie: the spindle is not in line with the axle itself), moving them to the other side of the spring will give you about 6-8" of leverage. Jeep equals 0"
Cameron Gunlock
Old 04-28-2010, 08:33 PM   #25
addicted2dunes
This is the same reason why you'll never, ever see FRONT lift blocks sold for a 4x4. The further the spindle is from the spring the more leverage, the more axle wrap.
Axle wrap is when the axle actually rotates forward (or backward) esentially "wrapping" itself in the springs. You get this under load conditions, ie. bumps or braking. Lift blocks increase the axle wrap effect (kinda what you are talking about doing), I dont know the technical aspect of this, but I guess it is just because your adding distance between the spring, and axle itself. It'll weak'n the u bolt's over time and eventually break that way.
Cameron Gunlock
