Old 05-09-2002, 06:18 AM   #1
freebird
Active Member
freebird's Avatar
Post Crack at door hinge
Anyone ever this problem drivers door top hinge crack? Ever time I open door I see the crack give just a little bit. Thinking about just running a bead with a welder anyone ever try this? Any idea or suggestions..... Thanks
67 GMC 305E V-6
(Ole Blue)
Rust In Progress (RIP)
85 Harley FXRS
(Baby Blue)
67 GMC 305E V-6
(Old Blue)
85 Harley FXRS
(Baby Blue)
MEMBER OF THE DRUM BRAKE CLUB
freebird is offline   Reply With Quote
Old 05-09-2002, 07:42 AM   #2
Huck
Huck's Avatar
Post
Common problem on our trucks. Welding bead on sheetmetal will not help. Best bet is either backplating or replacing door. Sorry but that's reality~~~~Huck
72 Cheyenne, 350, 5spd, LWB, Super trim.
71 GMC JIMMY 4X4 --needs stuff-!
Huck is offline   Reply With Quote
Old 05-09-2002, 08:02 AM   #3
JimKshortstep4x4
Smile
We have welded several doors with the cracks and have not had one weld fail in any of the doors. Maybe we have not seen enough time go by, but some of the welds are over 10 years old. We always sand blast the area prior to welding and if the material looks good after blasting and the crack width is 1/8" or less we simply weld with a wire welder.
Some of our doors have rust and are cracked and those we plate with 18 gage sheet metal.
This has been our experience for what it is worth.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-09-2002, 08:05 AM   #4
Randy70C-10
Randy70C-10's Avatar
Post
I welded mine too. It's only been a year though.
Randy70C-10 is offline   Reply With Quote
Old 05-09-2002, 08:35 AM   #5
tom hand
CCRider
tom hand's Avatar
Post
I had this problem on mine,it seemed to be from the door being "sprung"[opened too far maybe from backing into something] I welded the crack in place to try and fix the problem,but the weld warped the door and I had to put shims under the bottom hinge to get the door to shut. When I restored the truck I took the door off,straighten the spot and rewelded it and I have had no problems
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-09-2002, 08:37 AM   #6
StingRay
StingRay's Avatar
Post
Make sure the outer is securely plug welded to the structure behind it. Repair any bad spot welds and add a few new ones if need. It'll help alot.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
