Old 05-07-2007, 02:29 PM   #1
e rock
Stock mechanical fuel pump output?
How much can I reasonably expect the stock mechanical fuel pump on a '71 350 to put out?
The new motor has considerably more power and will be running a ~700cfm Holley, but I'm told that I should have at least a 750cfm on it. The builder says redline is around 7500rpm, but I'm not racing it and realistically it'll just be serving daily driver duties. I have a Mallory 110 electric pump (and 140 filter) that I can put in, but I'd rather keep it simple if possible. I know there are high-output mechanical pumps as well - are they worth the $$$?
Thanks,
Eric
e rock is offline   Reply With Quote
Old 05-07-2007, 02:51 PM   #2
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: Stock mechanical fuel pump output?
Does the 110 mean the PSI? If so, a carburator is only designed to handle from up to about 7 PSI.
72 cheyenne pdx is offline   Reply With Quote
Old 05-07-2007, 02:54 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I think stock output is around 60-70GPH.
More info on Holley's site:http://www.holley.com/data/Products/...ech%20Info.pdf
I would run a Carter personally.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-07-2007, 02:57 PM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
110 probably means GPH.
No you won't need that IMO.
I have run nothing but the Carter line of mechanical pumps and, many times stock over the counter fuel pumps on even many of my race (Circle Track) engines. Never a problem.
Also IMO the 700 cfm carb will be more than enough to supply a built 350 SBC. Specialy on a daily driver.
Summit Carter Fuel Pumps LINK
RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 05-07-2007, 03:06 PM   #5
e rock
110gph free flow. ~90gph @ 6psi.
Thanks for the link and recommendations. I think I'm settled on keeping the mechanical setup now and if the stock pump gives me problems, I'll order one of those Carters. Even the sub-$40 stuff looks like it would be fine for what I need. That's considerably cheaper than the $100+ ones I'd seen before.
Old 05-07-2007, 03:19 PM   #6
RACINJASON22
GEARHEAD
e rock I have ran the 23 and 24 dollar Carters more than any of the ones listed there with no problems at all.
IMO your stock pump will suit your needs fine and do as you stated if you have problems.
Note the Carter Pumps are rebuildable but who would at the prices they sell for
RJ22
Old 05-07-2007, 03:44 PM   #7
Billla
Billla's Avatar
Stock pumps deliver about 60 GPH @ about 6 PSI.
There are typically two types of aftermarket mechanical pumps based on if an external regulator is required (output PSI > 7 PSI)
It's pretty tough to flow 110 GPH unless you're well over 1.4 HP/CID.
Billla is offline   Reply With Quote
Old 05-07-2007, 03:52 PM   #8
KFreddy
Active Member
KFreddy's Avatar
For a 350 ci. spinning like a Honda at 7500 RPMs that 700 cfm holley should be just fine. At 83% volumetric efficiency your engine needs 631 cfm, same motor at 90% efficiency need 684 cfm. You should be good to go with the carb you have.
For comparison I'm using an old school 3310 Holley/ vacuum secondaries on a ZZ454, top RPM 5800 when I'm killing it, at 83% volumetric efficiency the engine needs 632 cfm, at 90% volumetric efficiency, pipe dream here, I require 686 cfm.
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 05-07-2007, 04:50 PM   #9
e rock
See, I guess I'm fuzzy on estimating volumetric efficiency (or what it really means). I found one online calculator that had options for "stock" "mildly built" "built" and "full-on race" (or something similar), which I assume to be estimations of VE. While I'm definitely not racing with it (and rarely exceeding 5K rpm I'm sure), this motor was originally built to run 1/4s, so I was basing my estimations on that.
It's funny you mentioned that carb - it's the same one that came with the motor. I don't know anything about it... Do you know if it's possible to convert to an electric choke?
Thanks a ton guys. It's always nice to have some confirmation before blindly spending money.
Old 05-07-2007, 07:32 PM   #10
Billla
Billla's Avatar
VE is basically the ratio of the maximum physical volume in the engine to the attainable physical volume.
The approach to calculating (ROUGHLY) VE is the formula:
VE = (HP * 792001.6)/(AP * CR * CID * RPM)
AP = Atmospheric pressure in PSI = Pressure in Hg * .49113, or use 14.7 as a good rule of thumb value (standard pressure = 29.92 Hg)
Applying this, a 330 HP 350 turning 6500 RPM will approach 75% VE.
As for the carb, very simple as pointed out:
CFM = ((CI x RPM)/3456) x VE
So in your case 570 CFM...PLENTY of room
This electric choke conversion will work - the 3310 is basically a 4160 with a secondary metering block vs. a metering plate.
http://store.summitracing.com/partde...5&autoview=sku
Old 05-07-2007, 07:54 PM   #11
Billla
Billla's Avatar
BTW, there's a great article on estimating fuel needs at the link below:
http://www.chevyhiperformance.com/te...r_fuel_system/
In a nutshell:
Pounds of gasoline/hr = HP x BSFC, BSFC = .55 for a carb engine
GPH = (pounds of gasoline/hr)/6.2
Old 05-07-2007, 09:22 PM   #12
e rock
I :heart: this place.
Thanks Billla. BTW - from your avatar - you live in the Farm?
Old 05-07-2007, 11:29 PM   #13
Billla
Billla's Avatar
Yep :-D I see you're in Monroe too - whereabouts? Come help me with a '74 Blazer HEI install :-D
Old 05-08-2007, 03:05 AM   #14
e rock
I'm in the middle of the Fryelands. Once I get this motor back in the 71 (and my own HEI), I'd definitely be up for lending a hand.
Old 05-08-2007, 11:09 AM   #15
Billla
Billla's Avatar
Well, if I can help in any way drop me a line! billla@warbird.org.
Hope to see you at the swap meet!
