one quick question.
does anyone have the dementions for the rear u bolts.
from inside to inside, the hight, and the diameter of the bolt
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Re: one quick question.
ttt
Is the u-bolt on a 2 WD or 4 WD?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
It's a catastrophic success.
![]() Join Date: Jan 2003
If you are looking for longer or blocks here is a site.
http://www.stockcarproducts.com/trkarm1.htm |
![]() Join Date: Mar 2003
coil spring or leaf spring
coil spring 2wd
its a 3/4 inch stock... and if you know the width of the axle housing tube than you know the width from inside to inside...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
