Old 05-09-2007, 09:30 AM   #1
Luvlegs
Luvlegs's Avatar
Can anyone identify this HEI?
I pulled this off a 69 GMC - it was on a 250 (motor mounts were directly across from each other) - can anyone tell me what it is? It had the coil mounted on the block. The coil had a split in it - is this something I could replace? I'm thinking about putting it on my 72, 250. Thanks all!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-09-2007, 10:22 AM   #2
D13
D13's Avatar
Re: Can anyone identify this HEI?
Later model HEI, looks just like the one on my 1982 3/4 ton w/250. If the coiil is split its junk. Good change the module is popped too.
D13 is offline   Reply With Quote
Old 05-09-2007, 11:36 AM   #3
Luvlegs
Luvlegs's Avatar
ok on the coil - junked - could you elaborate on the "module"? That's not a "toss it in the trash thing" is it?
1972 C10 L6 3OTT
Old 05-09-2007, 11:47 AM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I've seen that before. I knew a guy who had one of those in a early 70's (Canadian) Pontiac full size. His coil was cracked too but still ran. We had no money so he never fixed it.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 05-18-2007, 09:11 AM   #5
D13
D13's Avatar
The way these work is just like a V8 only the coil is outside. A pickup coil sends a pulse to an electronic module that acts like points, turning current on and off thru the coil to create high voltage at the tower which then feeds the cap and rotor which sends it to the plugs.
The module is in the distributor.
If the coil broke from water getting in it and freezing, well and good. But if it failed and overheated and/or shorted, the module may have seen voltage spikes or high current and popped. They are a simple change, just like a point set.
Old 05-18-2007, 11:47 AM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
An MSD coil gives those a kick and looks good too!
PICKMUP is offline   Reply With Quote
Old 05-18-2007, 05:56 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've got one of those but haven't installed it.The guy I got it from told me it was from a 75.If you find more info one these please post.I plan on refurbishing it and installing this summer.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
