gas gauge
hi
put a subburban tank in rear of my 67 pickup--new tank with new sending unit--when i fill up the gauge reads about a 1/2 inch pass full---is there an easy fix to bring it back to normal thanks bob |
Check GMC pauls web site. You need something in line for the suburban tank for the gauge to read correctly.
i have a stock tank and sending unit and mine has always done that since i've ridden in the truck 8 or 10 yrs.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Mine goes above full as well.As long as it reads empty on "E" and not 1/4 tank ,I'd say don't worry.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
So if the gauge reads between 1/4 and 3/8's of a tank when EMPTY, what's the problem? Bad sending unit or what? At full its about 1/4 to 1/2 inch past full. This is my situation.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
when mines empty it reads alittle a bove a 1/4 too it really botheres me wats up?
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
Spank 'em if you got 'em!
Just bend the lever! (worked on my original sending unit) lol
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
Sorry, but what lever are you referring to. I'm not too knowledgeable about this issue, so my apologies. The long rod with the float attached?
Right, my guage read wrong after I fixed the float (probably because of the added weight of the solder!LOL) Filled the tank and make the necessary adjustments by bending the rod. I know I reads just right now because I ran it on E for a while and was about 20 feet from the gas pump when it died.
Like I said, this worked on my old tank. New tanks might be a different story. It's always cheaper to bend then to buy. jmo
