Old 12-04-2002, 07:54 AM   #1
skyhawk1
skyhawk1's Avatar
Another Suburban problem
I'm getting about 9 miles per gallon. It has 350 with 350 auto. Edlebrock 600 with electric choke.
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 12-04-2002, 08:16 AM   #2
Cheesewagon
Cheesewagon's Avatar
Hi, well your doing about as good as I'm doing. I have the same engine trans-combo. There was thread on here about the Elebrock carbs needing only 5.5 lbs. fuel pressure. I believe my stock pump puts out about 9 lbs., so I'm going to try a holley fuel regulator. Did you upgrade to HEI? Believe me that really helped out with mine ( about 12 mpg highway). I'll talk to you latter, Tom.
'91 suburban 350 TBI - R 700 4 new daily driver
'72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers.
Cheesewagon is offline   Reply With Quote
Old 12-04-2002, 09:09 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
My burb does pretty much the same thing. When I got it many years ago, it did 16 mpg with the factory carb. It had a worn out throttle shaft so the idle varied 500+- rpm. I changed out the carb and it got 10 mpg. 2 years ago I rebuilt the engine, transmission, and had my mechanic rebuild the carb. On it's first long trip I averaged 14mpg. So I am on the right track.
I have the Edelbrock 1406 carb on my winter beater and I get 10mpg out of it too.
Either way, making a 2-3 ton brick move down the road and getting good gas milage are not usually synonomous.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
