Old 12-04-2002, 10:08 PM   #1
low 84
low 84's Avatar
Question custom inner fenders?
has anyone had made custom inner fenders, or know where i could get some made? i want to get some bigger ones with more tire clearence made so i can run taller tires in the front. as of now i can run a 27 inch tall tire and they rub very seldomly, but i want to run a 28 inch tall tire. anybody have any ideas????
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-05-2002, 01:08 AM   #2
brad2
I think N2TRUX did that to his blazer. I'm pretty sure that it requires a little surgury to the fender itself just for clearance. After that I'm not sure about fabbing some up or modifying the stock ones. One option would be to start with some aftermarket wheel tubs like pro street guys use and cut them down to fit. They would have a nice smooth radius and other that being slab sided on one end it could make for a clean install.
brad2 is offline   Reply With Quote
Old 12-05-2002, 11:38 PM   #3
bigblock73
yeller
bigblock73's Avatar
don't you mean UN-screw that!!
Removing the inners isn't always a good idea unless you like cleaning your engine bay ALOT.
bigblock73 is offline   Reply With Quote
