Old 05-17-2007, 09:58 PM   #1
paaw
paaw's Avatar
U joint
how do you know when they are bad, Have some vibration between 2500 and 3000 rpm, how can u tell if it is driveshaft, u joint, or what?
thanks paaw
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 05-17-2007, 10:08 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: U joint
They will clunk when you shift into gear usually. You can also grab it with your hand and twist it and see/feel movement.
I think it sounds like it’s your tires. Have you balanced them lately?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-17-2007, 10:14 PM   #3
Jim_PA
Re: U joint
I've had them cause vibes before they got to the point of clunking or feeling loose, but the only way to tell if they aren't obviously busted is to take them apart and look.
Jim_PA is offline   Reply With Quote
Old 05-17-2007, 10:20 PM   #4
Sport/Truck
Sierra Grande Club
Re: U joint
Was it only at a specific RPM range? Just wondering.
s/t
Old 05-17-2007, 10:20 PM   #5
paaw
paaw's Avatar
Re: U joint
I don't hear any clunking, will take it to get tires checked
Old 05-17-2007, 10:22 PM   #6
paaw
paaw's Avatar
Re: U joint
not really just once i got over 60 it will start vibrating
Old 05-17-2007, 10:22 PM   #7
Sport/Truck
Sierra Grande Club
Re: U joint
If they are the same size, you can have them rotated too.
s/t
Old 05-17-2007, 10:24 PM   #8
Sport/Truck
Sierra Grande Club
Re: U joint
Does it seem to go away if you go faster than the speed that is starts to vibrate?
s/t
Old 05-17-2007, 10:26 PM   #9
lbpd719
Zappaphile!
lbpd719's Avatar
Re: U joint
any noise? sure it's not in your rear diff??
Mine has a hum that starts at about 45'ish and gets louder as speed increases.. new rear gears is on my list because of it..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 05-17-2007, 10:28 PM   #10
sodak69c10
sodak69c10's Avatar
Re: U joint
my truck vibrates over 60mph turns out i missing a tooth off the ring gear.
a kid in my class has a mustang that had about an 1/8"(no joke) of slop in the rear u-joint it vibrated
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 05-17-2007, 10:38 PM   #11
paaw
paaw's Avatar
Re: U joint
going to take it out on the interstate tomorrow and see if it stops after a certain speed and listen to see if it is whining(humming). did not vibrate, before changed trans, also had diffferent tires put on back. Don't think the guy balanced them. went from 235-70-15 to 275-60-15
Old 05-17-2007, 10:45 PM   #12
Sport/Truck
Sierra Grande Club
Re: U joint
Look over your drive shaft for any dents, fresh signs of abrasions that could possibly have removed a weight from you drive shaft. I doubt it's that, but look to make sure.
I still think its your tires - especially since you don’t think they balanced them.
s/t
Old 05-17-2007, 10:57 PM   #13
sodak69c10
sodak69c10's Avatar
Re: U joint
agree
,Clint
Old 05-17-2007, 10:57 PM   #14
Jim_PA
Re: U joint
s/t
The ones I just replaced would give me some vibes under a light (yet specific) load condition. Going over a certain speed would make it worse, but it was more related to load and MPH than RPM.
Old 05-18-2007, 04:22 AM   #15
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: U joint
it could be nothing, happened to me, i thought it was something with the drive shaft but the joints and the bearing are good so i balanced the tires, still there, the gears in the diff are fine and yet it still does it a bit, my brothers 05 f250 4x4 does it, my brother inlaws 95 nissan 4x4 does it, so it could just be something you didnt notice before and now for some reason you do, just like i did
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-18-2007, 12:27 PM   #16
sodak69c10
sodak69c10's Avatar
Re: U joint
could be harmonics to if it does it at a specific speed not above or below it maybe everything is just right and magnifies a smaller vibrations?
beats me,
well, time to go back to work now
,Clint
