Old 05-18-2007, 04:04 PM   #1
Mixup
1958 with a 1955 nose
Hi, I'm from the 67-72 board and I'm buying a 1958 1/2 ton pickup. I want to put a 55 nose on it. Anyone know what needs to be changed besides the hood, grille and fenders?
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-18-2007, 04:08 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 1958 with a 1955 nose
Sorry thats not allowed. 4 lighters must stay that way. Only Cal was able to do that because he bought his that way.
Anyway to the older truck portion. I'm sure someone will pipe in with the info.
and of course pictures are always welcome...
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-18-2007, 05:17 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
First send me the fender from the 58 then do what ever you want. Then
You may have to move the radiator support mounts but not sure.
The frame in a 58-59 is 2.5 inches longer past the fron axle so you may have to trim the frame horns so the bumper won't stick out. But other than that I think its a bolt on deal.
Old 05-18-2007, 06:52 PM   #4
Mixup
The frame won't be a problem, it's on a 90 pickup frame. The guy that did it has done a few like that. He did a great job you can't even tell it's been changed until you look underneath. I have a 69 pickup that I just finished which I'm keeping. I don't know anything about what parts interchange on the 58 but I've seen a few with the 55 nose. Thats why I'm asking. The deal to buy the truck isn't done yet. I want to get all my ducks in a row before I buy it. It's painted with flames and was done about 5-6 years ago. The truck has been sitting since. It needs everthing. Right now it's a shell and chassis thats it.
1969 Z28 engine
Turbo 350
Old 05-19-2007, 08:41 PM   #5
chevyrestoguy
chevyrestoguy's Avatar
You'll need to redrill your '58 firewall to match the bolt pattern of the '55 hood hinges.
________
BMW 7 SERIES HISTORY
chevyrestoguy is offline   Reply With Quote
Old 05-23-2007, 03:17 PM   #6
5Mike7
No, no drilling required
I sold my '59 with a '55/'56 front clip on it....thing is you mentioned it's on a '90 frame, so all bets are off...but, you shuold have a direct bolt in with '55/6/7 stuff...only difference in frame in the '55-'57 vs the '58 and '59 are that the '58/9 extend a few inches out (for sheetmetal purposes) in front...so you might have an issue with your bumper looking a little "bucktooth" unless you trim the frame some.
I'm also about 99% sure (but it was 25 years ago when I did the swap) I had to use the '55/6 inner fender wells too with the '55/6 fenders.
55-9 stuff that need a new home http://67-72chevytrucks.com/vboard/s...d.php?t=226133
5Mike7 is offline   Reply With Quote
Old 05-24-2007, 12:43 AM   #7
55dude
55dude's Avatar
post some pic's dude! lets see it sounds cool.
55dude is offline   Reply With Quote
Old 05-24-2007, 02:11 AM   #8
MrSinister
MrSinister's Avatar
5MIKE7 is correct in that the inner fenderwells need to switched since the hood spring mounts to them. The outer bumper brackets are also different but it won't make any difference since you are using a differnt frame.
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 05-24-2007, 01:52 PM   #9
b.sharp
b.sharp's Avatar
You will basically need the hole doghouse off a 55-57 truck. Everything on the '58-59 doghouse is different. I thought about doing the same thing but a doghouse would cost more than I gave for the truck. And it seams like no one wants the dual headlights. Someday they will be worth more original than the single light front ends. Make sure you get one without rusted out fenders or hinge brackets. The after market fender are a bit pricey.
Lots of luck with the build if you get the ride.
Latr, B.Sharp
b.sharp is offline   Reply With Quote
Old 05-24-2007, 03:28 PM   #10
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i'm keeping my 4 lights on mine. i wish i could use the 55 hood, though
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 05-24-2007, 05:23 PM   #11
Mixup
Well if I get it I might keep it the way it is. Right now we are trying to agree on a price but so far he won't budge.
1969 Z28 engine
Turbo 350
Old 05-24-2007, 11:52 PM   #12
chevyrestoguy
I bought my '59 and it already had a '55 clip on it, but when I put a brand new set of '55-'57 hood hinges on it, I had to slot the two lower attach holes on the firewall for them to line up. I compared the new hinges to a set of '58-'59 hinges and the bolt patterns were slightly different. Easy fix, but I thought that maybe Mixup might need to know the little stuff that always drives you up the wall.
________
Ford Super Duty History
Old 05-25-2007, 03:22 AM   #13
55ChevyPU
55ChevyPU's Avatar
They do? I dont have a hood spring attached to the inner fenders O_O
55ChevyPU is offline   Reply With Quote
Old 05-25-2007, 06:33 PM   #14
Mixup
Thanks guys for all the help.
1969 Z28 engine
Turbo 350
Old 05-27-2007, 01:56 PM   #15
5Mike7
Latr, B.Sharp
I would have swapped my front clip back for a '58/9 one if I could have found something reasonable...just to make the truck "original" again, would have added quite some value to it.
