Old 05-20-2007, 01:33 PM   #1
HAVA79
Master Blaster
HAVA79's Avatar
My blazer pics
I hope that these post ok.
HAVA79 is offline   Reply With Quote
Old 05-20-2007, 01:38 PM   #2
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
More pics. Try to imagine the blaz a bright yellow(maybe next fall). I still have to add the new air ride management and finish some firewall work. Then lots or odds and ends...........jesse
Old 05-20-2007, 01:42 PM   #3
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
Thanks for all the help in getting the blaz this far. I read these forums regularly
Old 05-20-2007, 01:46 PM   #4
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
still more pics...........
Old 05-20-2007, 01:50 PM   #5
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
Last set.........for now
Old 05-20-2007, 02:04 PM   #6
los-lowrider
los-lowrider's Avatar
Re: My blazer pics
Sweeeet one you got there!
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 05-20-2007, 02:20 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
Re: My blazer pics
Lookin' CLEAN!
What serpentine setup is that? I've never seen one with the A/C compressor on the passenger side like that.
Pyrotechnic is offline   Reply With Quote
Old 05-20-2007, 02:26 PM   #8
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: My blazer pics
nice truck
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 05-20-2007, 02:30 PM   #9
boatpuller
boatpuller's Avatar
Re: My blazer pics
that is one fine blazer........how'd a/c turn out,happy with it?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-20-2007, 02:35 PM   #10
los-lowrider
Re: My blazer pics
How much did you drop it? And what size are the wheels?
Old 05-20-2007, 02:58 PM   #11
benoit454
Chris
benoit454's Avatar
Re: My blazer pics
Nice ride.
What kind of drop does it have, and is that a vintage air setup or what?
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 05-20-2007, 03:05 PM   #12
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
serp setup is from gm performance(all new) you can get the same stuff from early to mid 90's camaro I think. Others will have way more info. the kit from gm ram me about 750.00$ all new and every nut and bolt to complete(reverse water pump, power steering pump, alt., air compressor, idler). Boatpuller, I love the A/C from vintage , It is above my expectations!!(yet pricey )
The tires are 245/40/20 front and 295/40/20 very pleased here also, next fronts might be 245/50/20. Just a little more sidewall, this is driven as much as possible
Old 05-20-2007, 03:11 PM   #13
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
Drop: all airride, four-link in the rear with Blackbirds rear disk conversion(highly recommend) standard bags and plates up front. The air bottle will be coming out of the rear and in goes the new airride electrics with a 5 gal. tank and two compressors with valves and pressure solenoids. I just dont trust the 10 pound bottle, no way to generate your own air if you have a problem.(tried to go simple and cheap, just dont trust it on a 5 hour drive to san diego )
Old 05-20-2007, 04:08 PM   #14
alextreme76
alextreme76's Avatar
Re: My blazer pics
gosh, there are so many AZ members on this forum!
'86 Longbed 305
quasi-rat-rod father/son project
alextreme76 is offline   Reply With Quote
Old 05-20-2007, 08:36 PM   #15
cochino12
It followed me home?
cochino12's Avatar
Re: My blazer pics
Very nice Blazer, would you mind taking a closer pic of the roll pan? I'm curious how far the tank hangs below the rollpan. Thanks and the seats look great, do you mind me asking what it cost to get the rear recovered?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-20-2007, 08:52 PM   #16
Eyegore
What Hump?
Eyegore's Avatar
Re: My blazer pics
Very nice.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-20-2007, 08:55 PM   #17
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
rollpan was on the blaz when i purchased it. the tank hangs down pretty far . I am still trying to decide to put a bumper back on or not. I need a trailer(hidden) hitch to tow my boat and I think the stock hitches will hang down way too far . I like the pan so will try to have a custom hitch built for it.
As far as the rear seat, I had the seat done and the carbon fiber looking side panels, along with the carpet glued to the mat over the dynamat at the same time. I am not sure about just the seat price, I do know that using GM material is more than just about anything else . But I wanted it to match the fronts...........jesse
Old 05-20-2007, 09:31 PM   #18
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: My blazer pics
Nice setup. What type crate motor is that? How did you route the heater hose? I'm trying to work mine out. Does your water pump have two ports or one port? I'm adding a similiar serpentine belt to my 83.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-20-2007, 10:02 PM   #19
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
Motor is a zz4, the water pump is a reverse rotation short for the serp setup. I believe it only has one port for the heater hose other heater hose is on the intake. Do a search for Gilbert cheverolet, they used to be named sallee chevy, very good info on the performance parts stuff.
Old 05-21-2007, 12:36 AM   #20
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: My blazer pics
Good looking Blazer, inside and out.
BTW, what's sitting on the roof?
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 05-21-2007, 08:57 AM   #21
gchemist
gchemist's Avatar
Re: My blazer pics
Which hose did you use as a supply? Return?
Does the bracket to the passenger side head only use two bolts?
Old 05-21-2007, 01:20 PM   #22
Ric83
Ric83's Avatar
Re: My blazer pics
Sweet looking blazer!! Good idea on the front tire meat. I was looking at the pix saying " that would look sweeter with more meat on the front wheels" lol
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 05-21-2007, 01:47 PM   #23
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: My blazer pics
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 05-21-2007, 04:36 PM   #24
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: My blazer pics
Very,Very Nice , love that smooth clean look, what color is she?
John
Malo83 is offline   Reply With Quote
Old 05-21-2007, 06:41 PM   #25
HAVA79
Master Blaster
HAVA79's Avatar
Re: My blazer pics
Malo- she is a $h!!tty champange color and a 20 footer at that , the paint is horrible but the body is rust free and I have dynamated the whole interior. she will be a rich bright yellow hopefully soon, just trying to get her just right before teardown for paint. Besides I need a little seat time, tired of just working on her .
