05-20-2007, 03:34 PM | #126 | |
Re: Xmas In March, Thanks To Porterbuilt.
05-20-2007, 06:25 PM | #127 | |
W/o the length of line, the air is warm/hot. Once it cools in the tank, there will be moisture.
05-21-2007, 09:03 PM | #128 |
Wire bags today, but not working right. The rear airs up on the blink of an eye, the front barely moves. Do you guys have any ideal as to whats going on?
05-22-2007, 01:17 AM | #129 |
thats a weight issue the engine weighs heaviewr on the bags you might want to restrict the flow to the rearbags a bit
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-22-2007, 08:22 AM | #130 |
05-22-2007, 10:17 AM | #131 |
Depending on how you have it plumped, you can use flow restrictors like I had to do to slow the fill and dump rates of my 1/2 system.
I used these from SD for fill control. [IMG]http://*****************/images/products/mid_1-2_PTC_Valve_Fill_Controls.jpg[/IMG] <edit> They just go inline with the fill line. If you don't have a line to run it, they have one with NPT holes for a nipple or fitting.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 05-22-2007 at 10:19 AM. |
05-22-2007, 12:21 PM | #132 | |
05-22-2007, 12:23 PM | #133 |
one pic.
05-22-2007, 08:18 PM | #134 |
I installed two on and off valve for the rear, so the rear works fine now, I can regulate the air so it goes up and down really good. The front I still cant get no lift, I don't know if is the valve or bags. you can See the front trying to lift, but it doesn't. Does anybody have an idea as to why . maybe I need different valve or bags.
05-22-2007, 08:32 PM | #135 |
plug the line from the front to one of the rear valves to see if it still does it
05-22-2007, 08:47 PM | #136 |
How much pressure is in the tanks? Sounds like there isn't quite enough to get it up.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-22-2007, 10:56 PM | #137 |
05-22-2007, 11:03 PM | #138 | |
ps. I still love my dropmenber. thanks Last edited by MEANGREEN70; 05-22-2007 at 11:04 PM. |
05-22-2007, 11:59 PM | #139 |
it takes alot more to psi to lift the front..so thats probably the deal
05-23-2007, 12:12 AM | #140 |
maybe a smaller valve in your rear will force more air to supply the front?
05-23-2007, 12:22 AM | #141 | |
150psi. is the minimum pressure switch I would run. It is going to take all of it to pop that front end up with that BBC hunkered in there. What is your pressure switch rated at? 150psi. should do fine, but you can get an adjustable one for fine tuning. I think it's just a pressure issue.
05-23-2007, 07:38 PM | #142 |
You guys were right, it was a pressure issue, I finally got the front end to lift.
The comp that came with the kit I bought maybe a 1or2, are not that great. It takes to long to fill the tanks, so I'm going to have to look for a different comp. |
05-23-2007, 08:47 PM | #143 |
Errrr. . . ..... make that 2 compressors.
06-16-2007, 08:53 PM | #144 |
I finally found a front clip, so is time to go back to work.
06-16-2007, 09:37 PM | #145 |
Ohoooo, looks very straight. Where did you find it?
06-16-2007, 09:47 PM | #146 |
Nice!
I just happened picked up a '68 front end last weekend. I'm not sure mines quite as nice as yours but it's close. I can't wait to start on my Blazer.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
06-19-2007, 08:07 AM | #147 |
06-19-2007, 01:57 PM | #148 |
go w/the viar 380's for compressors, you can get 2 on ebay for under 300 shipped
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-19-2007, 03:38 PM | #149 |
06-19-2007, 03:46 PM | #150 |
Since most are using the 380's I would say the 480's would work just as well. Got that front clip in place yet?
