05-21-2007, 12:01 AM | #1 |
need help with primer
hello im getting a used fender for my 69 chevy and im planing on taking it down to bare metal and use rust-oleum primer. i dont know if this primer is good to use or not.
05-21-2007, 12:05 AM | #2 |
Re: need help with primer
i was told not to huse rust-oleum bacause it might wrinkle under an oil based paint
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
05-21-2007, 07:39 PM | #3 |
Aluminum slot wheels rule...
ttt
05-21-2007, 09:23 PM | #4 |
Prestige member Old Farts Club
no rustoleum is not what it used to be years ago- it is just another "consumer friendly " oil based primer get some POR 15 or go to napa and ask them.
Hey sombodys gotta do it! |
05-21-2007, 09:40 PM | #5 |
If you're intending to overcoat it, then I'd recommend a good epoxy primer. I sure wouldn't try to overcoat Rustoleum or POR...
05-21-2007, 09:47 PM | #6 |
sorry I misread -I thought he was doing the backside, bare metal has to have a epoxy primer
05-21-2007, 09:47 PM | #7 |
CAN'T FIX NOTHIN
no don't put rustoleum on your fender , use a type of primer that will catylize with a hradner or activator , napa has a good high build two part primer that is awsome !!
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
05-21-2007, 09:51 PM | #8 |
Sierra Grande Club
Why not rust bullet? Seems easier than POR.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
05-21-2007, 10:08 PM | #9 |
The Original HotRod KnifeMaker
I had a few real bad spot I repaired under the core support and around the windshield and behind the heater core.
Ordered, read the instructions and followed them with Rust Bullet. It covered up just fine with the paint. I am sold on it and will continue to use it. Pretty amazing reviews of this stuff compared to other products. just my .02.
Dave 69 GMC SWB 2WD 454 Turbo 400 |
05-21-2007, 10:40 PM | #10 |
what i was planing to do was primer the fender and wait a year and and then paint my whole truck.
05-21-2007, 10:53 PM | #11 | |
I've had really good results with PPG DPLF primer; it can be applied over bare metal and it's a primer/sealer when mixed properly. Then when you're ready to paint - just scuff, surface and paint! Last edited by Billla; 05-21-2007 at 10:54 PM. |
05-21-2007, 10:59 PM | #12 |
Too many projects!!!
If your going over bare metal..you will want to use a "self etching" primer...
Sean 1995 Buick Roadmaster Sedan 2004 Chevy Trailblazer 5.3L V8 1963 Chevy Biscayne 4D Sedan 1971 Chevy C10 (now have 70 cab & frame) 1968 Chevy C10 (parts for the 70) 1991 Oldsmobile Custom Cruiser (Chevy 355 motor) 1937 Pontiac 8 4D Touring Sedan (in pieces) Jacksonville, Florida |
05-21-2007, 11:07 PM | #13 |
Questionable
well, i am probably in for a shocker. i just sanded down an inner fender with a ROS, then used Rustoleum's "rusty metal" primer (the brown stuff), then topcoated it with Rustoleum satin Black. I only did the side exposed to the engine bay, and it looks pretty damned good (it's only going to be like this for 1-2 years), so ...
Meh. I know nothing about paint. Maybe this is good enough, maybe it ain't. I don't have the resources or know-how to know what to use and how. I just know it looks good now, and it should fend off rust till I can paint it professionally.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-21-2007, 11:18 PM | #14 |
Hey, in the end - anything that keeps stuff from rusting is goodness.
