Old 05-21-2007, 09:03 PM   #1
396 SS
396 SS's Avatar
2000 5.3 with a miss. Need Help.
I have already put new plugs and wires, new fuel filter. The code is showing random missfire. I checked fuel pressure and it is showing only 47 psi when it should be 55-62 psi. Will this cause a missfire?
396 SS is offline   Reply With Quote
Old 05-22-2007, 03:53 PM   #2
Huck
Huck's Avatar
Re: 2000 5.3 with a miss. Need Help.
Doubt it. with new plugs and wires---I would try swapping out each coil with a new one till you find the mis. Did any of the plugs show a different color? I would also try some injection cleaner with your gas. There is a lot of crappy gas out there these days and that can drive you nuts. Does the mis happen at idle, under load, or ?
Huck is offline   Reply With Quote
Old 05-22-2007, 06:02 PM   #3
71 super
71 super's Avatar
My 5.3 showed misfire it was a coil, code should show number that is misfiring and the bank it is on driver side bank 1 pass. bank 2; 1-4 on each side if I remember correctly but not sure on the numbering system for the cylinders.
71 super is offline   Reply With Quote
Old 05-22-2007, 07:45 PM   #4
396 SS
396 SS's Avatar
I have run two bottles of injecter cleaner, with no change. It misses the worst at lower rpm under load . It was showing random missfire which he said was 6 or more cylinders.
Old 05-22-2007, 08:55 PM   #5
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
check your maf or o2 sensors...i've seen it cause that on those trucks(mine)
'85 swb
droppedgmc is offline   Reply With Quote
