Old 05-22-2007, 12:30 PM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
Solid axle camber adjustment...
Correct me if im wrong, but if the tops of my wheel face outwards and wear the outside of the tires, that means i have positive camber... Correct? I have a dana 60 in the front of my truck and i have replaced EVERYTHING on it so far. its basically brand new. but now i need to figure out how to adjust the camber on it. its eating my tires alive. Is there some sort of shim that goes behind the spindle or something? and if it is a shim... where does it go and how do i get the right one?
Thanks alot guys
-Scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 05-22-2007, 06:19 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Solid axle camber adjustment...
yes, top of wheels spread out is positive camber, no sure how to adjust yours though...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-22-2007, 11:16 PM   #3
Duro5341
Duro5341's Avatar
Is it eating the edges off?, or wearing half the tire?
Excessive toe will chew the edges off tires, and camber will wear half the tire
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 05-23-2007, 06:55 PM   #4
bbchevy
87 Wanna Be K30
bbchevy's Avatar
it's wearing half the tire off... can't figure out how to adjust it tough
Is: A wanna be K30
Old 05-24-2007, 10:57 PM   #5
bigtruck81
pull your kingpins apart and check their condition. if they're good, find another Dana 60, yours is bent.
bigtruck81 is offline   Reply With Quote
Old 05-29-2007, 10:44 AM   #6
Big Bobby O
I think Fords have a cam adjuster. As you turn it, the" offset hole will change the degree of camber. I would think that the others would have some way to adjust it too.
Big Bobby O is offline   Reply With Quote
Old 05-29-2007, 01:01 PM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
There is no camber adjustment on most straight axles, Dana's included (not really anyway, there are some things on the market to do a half a$$ job of it). Have you checked to see if your bearings are tight and your ball joints aren't worn out? If every thing is tight, then I agree that you might have a bent housing.
Sometimes your eyes can play tricks on you with the way the wheels and tires look, are you sure that your wheel has positive camber? (as in have you had it checked or measured it?)
It may well be that your tires are worn becasue of too much toe-in. I believe that would me much more likely than a bent housing.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-30-2007, 10:34 AM   #8
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
The guys here helped me out on this very problem not too long ago. My D44 solid front axle burb chewed through some BFG 37" A/Ts on the outer edge pretty quickly - around 5k miles was all it took to get them worn on the edges badly.
I always thought my truck had positive camber too, and I too thought I had a camber issue because it looked like to top of the tire stuck out. I took the truck in for alignment, and the guy said my toe was TOTALLY out of whack- way too much toe in. He aligned it, and the truck is right as rain, and the tires appear to be more straight up and down. Must be an optical illusion though. Maybe too much toe from the front gives the appearance of positive camber?
Funny thing, someone said I probably had a bent axle case too... No way. Take her in for an alignment. On our trucks, it's only a $50 venture since all they can really do is center the wheel and set toe.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
