Old 05-23-2007, 10:42 AM   #1
69c10step
69c10step's Avatar
Perhaps a stupid question
Does the wood floor in my 69 stepside give any strength to the rest of the box? I guess the real question is, if I remove the plywood bed floor that the PO had put in, will my bed fall apart while going down the road?
I told you up front it was a stupid question.
Tom
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 05-23-2007, 12:40 PM   #2
68 P.O.S.
Re: Perhaps a stupid question
It won't fall apart but, with no wood the only thing holding the bed to the frame is the rear cross sill. The rest of the bed bolts go through the bed wood to the frame.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-23-2007, 12:46 PM   #3
revn67
revn67's Avatar
and if you remove the bed wood, then i believe everytime you hit a pothole or a buig neough bump, then your headpanel will slap against the frame. don't quote me on that one though
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 05-23-2007, 02:22 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
The furthest front floor support is bolted to the bed and the steps so if you leave it in you will have four bolts holding the bed on, two front, two rear. I drove mine for a couple months like this and the PO drove it like taht for a couple years. Very light in the rear though, makes it real easy to spin the tires.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-23-2007, 06:53 PM   #5
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I mounted my 50' box to the frame and then put the wood in on top of the main hold down bolts so that these odd ball factory bolts could not be seen. On my 70' I'm in the process of putting in the new bed floor and on this truck I will be showing these bolts. The box will be fine as long as you put these bolts in with out the wood as the wood does nothing to hold the bed to the box. I've driven the 70' off and on over the last year like this.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-23-2007, 07:06 PM   #6
1970bowtie
1970bowtie's Avatar
thats not necessarily a bad thing
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 05-23-2007, 10:36 PM   #7
69c10step
69c10step's Avatar
.....Very light in the rear though, makes it real easy to spin the tires.
Hey, there's a plus.
Thanks for the input. It sounds like it should be ok to take it out for a little while. The plywood is de-laminating and is looks so bad I can't stand it, but not ready to put in hardwood yet.
