Old 05-24-2007, 09:58 PM   #1
indyracer
indyracer's Avatar
What the heck is this stuff????
I can't find this on the wiring diagram. What is it?
This green wire is on the passenger side. There is what appears to be a sensor in the head down there. If it was on the drivers side I would call it a temp sensor.
Here is the green wire for the temp sensor on the drivers side.
Now these blue and black wires go to a plug on the passenger side of the carb. What are they???
Here is the plug.
Well, these are my questions of the week. I hope my pictures are good enough to see what I am talking about.
Cheers,
Tony
A day without sunshine is like, you know, night.
1970 Chevy CST10 (Green)
2005 Silverado Z71
2000 Pontiac Bonneville
indyracer is offline   Reply With Quote
Old 05-24-2007, 10:03 PM   #2
Rupdog
Re: What the heck is this stuff????
can't tell if the pigtail next to the carb goes into it, or where it goes. only thing i can guess on the passenger side of the engine is maybe an engine block heater? do the wires connect to anything, or just hang there?
maybe they're A/C connection? that is definitely a circuit breaker, used for high-load electrical, such as A/C, etc...
Rupdog is offline   Reply With Quote
Old 05-24-2007, 10:06 PM   #3
Down south truckin
Down south truckin's Avatar
some of these trucks have 2 temperature sending units. my 72 super has 2 i really don't know why or which ones have it or don't but some do ? and the other one looks like a/c wires
Down south truckin is offline   Reply With Quote
Old 05-24-2007, 10:13 PM   #4
Big D
Big D's Avatar
My 70 GMC with a 250 six has the same thing on the firewall. The red wires disconnected. I 've never chased down the wires but there was a solenoid on the carb that the PO disconnected. I'd guess it was to bump up idle speed. My truck never had air, Does yours? I seen to recall a lot of old F*rds having a device to crank up the idle speed when the air was on.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 05-24-2007, 10:46 PM   #5
indyracer
indyracer's Avatar
No air on this truck. The 2 wires with the plug have a bracket connected to the intake that holds them.
Also, the red wire pointed out in this picture...
Is the red wire pointed out in this picture...
I also am pretty sure that the green wire in the first picture going to the breaker is the green wire that goes to the sensor in the head on the passenger side. I am going to do some more tracing this weekend.
Cheers,
Tony
2005 Silverado Z71
Old 07-02-2007, 11:24 PM   #6
indyracer
indyracer's Avatar
Okay, since I am removing the engine from the truck, it gave me a chance to look closer at this section of wiring. This wiring only consist of the wire that comes from the firewall by the fusebox, the wires from the breaker type connection to the plug on the passenger side of the carb, the wire that goes to some sort of sensor on the passenger side head and a wire that goes to the transmission. It kind of appears that it was added later, but the tape around the wires has orange paint on it like it was there from the factory. I am a little confused...
Cheers,
Tony
2005 Silverado Z71
Old 07-03-2007, 12:16 AM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My 72 has the same plug next to the carb, but it isn't connected to anything either. I've looked for where it should connect, but I haven't found it yet. Let me know if you figure it out.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-03-2007, 06:37 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
for some strange reason I think it all has to do with electric overdrive transmission controls.
68C15 is offline   Reply With Quote
Old 07-03-2007, 07:22 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
Transmission controled spark advance. Does the sensor bolted to the intake have vacume advance hoze going to it or a place for hozes to go to it? If so thats what it is.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-03-2007, 08:30 AM   #10
Stoney
Farm Truck
Stoney's Avatar
It engages the A/C compressor to keep the engine from dieseling when you turn the key off. And the other is to idle the engine up when the A/C is turned on. Mine still work today.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 07-03-2007, 09:18 AM   #11
jkaylor68gmc
jkaylor68gmc's Avatar
A relay maybe?
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 07-03-2007, 09:21 AM   #12
indyracer
indyracer's Avatar
I am starting to lean towards the transmission controlled spark advance. I saw a harness on a vendors website and that clued me in. There is a vacuum hose that goes from the manifold to the transmission, I don't know if that is what you are talking about.
Cheers,
Tony
2005 Silverado Z71
Old 07-03-2007, 09:57 AM   #13
OLDCHEV4X4
OLDCHEV4X4's Avatar
That hoze is for the vacume modulator on the trans. The hoze i'm talking about would be between the distributer and the carb. The sensor would be inbetween the two with a line coming in and a line coming out. Sometimes they are eliminated and all thats left is the wires and relay.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-03-2007, 10:05 AM   #14
indyracer
indyracer's Avatar
Could have been eliminated. My vacuum hose from the distrubutor and the carb is one piece.
Another question is what does "transmission controlled spark advance" do and since it seems it wasn't connected to anything, can it be removed?
Cheers,
Tony
2005 Silverado Z71
Old 07-03-2007, 11:17 AM   #15
bouncytruck
SKINNY TIRES RULE!
Can you post a pic of where it plugs in?
bouncytruck 1972 K5
Old 07-03-2007, 11:21 AM   #16
ERASER5
ERASER5's Avatar
The wiring pictured is definitely the TSC system.
Originally, the two-wire plug close to the carb went to a vacuum switch that interrupted the vacuum advance.
The relay on the firewall was controlled by both a temperature sensor in the right head and a pressure sensor in the transmission. The temp sensor closed if the temp was above 32° F and the pressure sensor checked for third gear. In order to get vacuum advance, the engine had to be warm ( not freezing) AND the transmission was in third gear.
Now that you know WHAT it is, you can happily yank the wiring out and use the keyed hot wire for your new electric choke carb like I did.
P.S. I found this out just like you did right here on the board.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-03-2007, 12:53 PM   #17
indyracer
indyracer's Avatar
With further research, it seems this is an emissions control thing.
To that I say, We don't need no stinking emissions control...
Cheers,
Tony
2005 Silverado Z71
