Old 05-25-2007, 03:53 PM   #1
va_tlc
va_tlc's Avatar
3/4 ton rear block ???
can someone with a 3/4 check the block under there rear springs and see which way it goes, i took mine out and did not relize it is wedged shaped my question is doe the bigger part of the block go towards the rear and the thinner end go towards the motor.. thanks in advance...... ohh and its not a aftermarket type block i guess its factory if that makes a diffrence
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 05-25-2007, 03:55 PM   #2
jimmydean
jimmydean's Avatar
Re: 3/4 ton rear block ???
If it is a wedge shape, it SHOULD go with the fat end facing the back. The idea is to angle the rear axle up to lessen the pitch of the driveline to 3rd member joint.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-25-2007, 04:21 PM   #3
va_tlc
va_tlc's Avatar
thanks jimmy thats kinda what i thought, i have them in wrong, thats what made me think thee wrong the driveshaft angle loks pretty bad, im hoping its that simple cause i changed out rears and had to reweld the spring perches, that made me worry thinking we had those off some thanks again
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 05-25-2007, 05:37 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
However, the oem blocks under my K20 aren't tapered...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
