![]() Join Date: May 2007
newbie needs help!
hey i am a newbie here! and i need your help. i am doing a frame off on my 66 chevy and i cant get any of the bolts for the rear u bolts and spring bolts loose. i have tried penatrating oil, impact wrench, breaker bar and took the torch to it and no luck. anyone have any tricks that i might try? thanks for any advice.
Designated A-hole!
Re: newbie needs help!
Welcome to the board from South Mississippi! Oxygen-acetylene and a BFH is the only thing I can think of.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
use the torch to cut them, if they are that rusted you dont want to save them anyway.
61 swb step 63 swb fleet |
yea, on my parts 62 every nut, bolt, and stud was rusted. the good ole grinder helped me alot!! lol but whats weird is my 66 nothings rusted on. so idk
good luck, John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
WELCOME to the board
just torch them off and put in some nice new ones
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Justified!
Yep, I tried soaking mine in Kroil, WD-40, and nothing helped....
finally just used the die grinder and cut them off......5 minutes and your done!!!!!
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
i can cut the u bolts no probelm there but what about the bolts for the rear springs. if i cut them off then i have to buy new trail arms??? i dont want theat expense. any thoughts?? tha
![]() Join Date: Apr 2007
Cut'm Just went thru the same thing
U-bolts are not that expensive.Save the agravation and busted knuckels Good luck Pat |
Spring bolts are replaceable
