Old 05-26-2007, 11:23 PM   #1
rikyric
rikyric's Avatar
rear end
My rear diff was leaking so I decided to change the cover and replace the fluid. Wasnt sure if it had a posi in it. Is this a posi unit? And how much fluid does it take?
rikyric is offline   Reply With Quote
Old 05-26-2007, 11:24 PM   #2
1969k10stepside
Re: rear end
Yes,thats a posi rear axle.I fill mine up till the fill plug where it's about to pour out.
1969k10stepside is offline   Reply With Quote
Old 05-28-2007, 01:57 AM   #3
rikyric
rikyric's Avatar
Re: rear end
cool thanks.... does the posi need any special type of gear oil or additive?
Old 05-28-2007, 07:27 AM   #4
Blazer1970
Blazer1970's Avatar
Re: rear end
Yes, you need a limited slip additive, or a gear oil that already contains the additive.
Blazer1970 is offline   Reply With Quote
Old 05-28-2007, 05:15 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: rear end
Yes, U lucky B@$tard
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-29-2007, 11:44 PM   #6
69TowRig
Re: rear end
Lockers are better anyway. If you're not locked, you're stock! The Eaton Posi is a nice thing to have otherwise.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 06-09-2007, 06:14 AM   #7
old man jimmy
Re: rear end
Just for information. That is an Eaton you have their guy. I have one just like it in my 72. Have had to rebuild it several times. Had a heavy foot when I was younger. Good units, but not real strong. Like the guy said, Just fill it till it comes out the hole while the truck if level. If it starts klunking when you back up, add some additive to it. they use to sell whale oil for the clutches. Now it's synthetic.
old man jimmy is offline   Reply With Quote
