Insert Title Here
post pics of 6/8 drops
anyone have any pics of a truck dropped 6/8? thanks
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Re: post pics of 6/8 drops
heres a 6/7 drop..
Approx 6/8 drop.....
damn
Insert Title Here
you think this could be a 6/8 drop
It Is What It Is,,,,
What was used to drop everything?
Coils, LCA, spindles,UCA? Flip kit, hangers,shackles? All those rides lookin SCHAWEEEEET!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
Insert Title Here
If I was to do it... it would be
Front: 3 inch spindles, 3 inch springs Rear: 6 inch spring, 2 inch blocks, adjustable pan hard, and a notch
#8 | |
My 68 is 3" BellTech spindles, 1 coil cut from the original front springs, rear air bags, bolt-in c-notches (they're now welded in too), 1.5" lowering blocks, adj panhard bar, modified & relocated stock rear shock brackets. I think the best 'budget' compromise for the front would be: 3" spindles, 1 ~ 1.25" notched front crossmember & 1" drop springs (or cut 1-coil from the stock springs & use a 1" urethane coil spacer). This would offer the most suspension travel while still not breaking the bank.
