Old 05-31-2007, 11:15 AM   #1
RckyMntnKng
RckyMntnKng's Avatar
Rear seat support
Guys
I picked up an original bench seat to go in my Jimmy, just needs the fabric re-done
I need the frame that the seat mounts to (Between seat and bed)
Anyone know where I can find something like this.....dont see it on LMC or Brothers?
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 05-31-2007, 03:06 PM   #2
mattstoc
Re: Rear seat support
For what is worth, I have had no luck finding the cargo area bench seat stuff either.
I posted a few days ago for ideas on the front mounting clips for that seat. Someone mentioned e-bay for around $50. That is expensive - so I am continuing digging through my parts boxes looking.
Matt Stockton
mattstoc@dfwair.net
972-924-2293
mattstoc is offline   Reply With Quote
Old 05-31-2007, 04:47 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
The front mounting clips tend to go in the $50-65 range. I've seen them as high as $90. There was a board member making them out of blocks of aluminum several years back but I haven't seen him around in a few years.
As for the "legs", you can post a "wanted to buy" listing on the board and I'm sure someone will have what you are looking for. They are the same as the suburban, but I'm not sure if it is the 2nd row or 3rd row seat. No repops are being made.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-31-2007, 04:54 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nope,
Gotta be a subscriber for WTB adds, Sorry
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-31-2007, 05:12 PM   #5
71chevylowrider
71chevylowrider's Avatar
Not too familiar with Blazer seat parts, but I found this for you, look at the picture & see if it has the brackets for the back also.
http://portland.craigslist.org/wsc/pts/340014469.html
71chevylowrider is offline   Reply With Quote
Old 05-31-2007, 05:18 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
71,
Those are for the front buckets, cool deal though
For the rear seat also try Burb 3rd row parts
Old 05-31-2007, 05:22 PM   #7
71chevylowrider
Sorry, the guys ad said "Complete set of seat brackets for a Blazer" oh well, we were close huh?
Old 05-31-2007, 05:52 PM   #8
bouncytruck
SKINNY TIRES RULE!
Originally Posted by LUV2XCLR8 View Post
Nope,
Yep, just gotta pay the fee and they can post away (I didn't say there weren't a few steps first.)
bouncytruck 1972 K5
Old 06-01-2007, 10:16 AM   #9
RckyMntnKng
Looks like I need to become a supporter of this great site!
Just for my own information.....What holds your original rear set to the bed in your Jimmys/Blazers?
My seat has "L" type brackets, but they dont line up with the factory holes.....I was told it was a stock seat from a 71 jimmy.
Just confused on what I even need to look for...I was thinking there was some kind of assembly between the seat and tub that I must be missing. Otherwise I just have the wrong brackets....like from a Sub or something
Old 06-01-2007, 11:24 AM   #10
bouncytruck
SKINNY TIRES RULE!
I've tried to attach some photos that show the brakets. In the back there are 2 or 4 legs (depending on your truck). In the front, there are tubes that rest on the floor and then there are metal "clamp" that bolt down to the floor. The front pieces tend to get lost easy so they sell for a premium. Sorry, I don't have any photos of them but hopefully someone else will.
bouncytruck 1972 K5
Old 06-01-2007, 11:35 AM   #11
RckyMntnKng
Bouncy,
Thanks so much for the Pics...that helps tremendously.
I have four rear holes in my bed, and only 2 brackets on the seat.....
I need to be looking for a set that matches a 4-bracket rear!
Thanks again
Josh
Old 06-01-2007, 11:46 AM   #12
smbrouss70
smbrouss70's Avatar
Found this today, just thought I'd pass it on. http://cgi.ebay.com/ebaymotors/69-72...QQcmdZViewItem
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-01-2007, 11:57 AM   #13
RckyMntnKng
Ahh cool.... thank you.
Old 06-01-2007, 12:57 PM   #14
bouncytruck
SKINNY TIRES RULE!
My '72 has 4 holes in the floor, but only two legs on the seat and it is completely stock. The two center holes have seat belt bolts in them. Here's a pic of the back of my seat.
bouncytruck 1972 K5
Old 06-01-2007, 03:56 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, those hold the front tubes down, and the rear legs just bolt down.
That seller used to be a active member here, always has very nice parts.
Pic one has Blazer Rear legs (Top Row)
Also Burb 2nd row rear legs (Left Side)
& Blazer front tube hold downs (Btm Row)
Pic two shows the Blazer front tubes
Old 06-01-2007, 09:22 PM   #16
Huck
Huck's Avatar
Blazers came with several different configured rear seats---some with 4 rear mounts, some with seat belts bolted to the rear mounts, some with the outer belts mounted to the side bolts of the seat. There is a heavy duty bracket under the floor to brace the rear seat mounts in case of an accident. there are 4 holes in the floors and in this bracket for the rear seat mounts.
Huck is offline   Reply With Quote
Old 06-02-2007, 05:38 AM   #17
vtblazer
vtblazer's Avatar
Good addition Huck.
Rcky, use the "correct" seat mounts and mounting position in the truck, otherwise your just tempting fate.
Throw out the shade-tree mounts and clamps that you've described that's in there currently and make it right.
Another pic of the front clips for ya.
vtblazer is offline   Reply With Quote
Old 06-04-2007, 10:59 AM   #18
RckyMntnKng
Thanks Gentlemen...appreciate all your help.
Ive got a line on some good stock parts to attach my seat.
Will post pics after I get the new fabric and mounts done
Old 06-08-2007, 06:47 AM   #19
K5 Blazer
Blazerologist
K5 Blazer's Avatar
Probably a day too late but, if you still need anything, give me a call.
www.californiak5.com
K5 Blazer is offline   Reply With Quote
