Old 05-31-2007, 10:41 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Replacing tank, what else needs to go?
I bought a 69 that had been sitting for 15 years. It had 3 tanks the orig and two aux tanks. I have replace the old tank in cab since truck is all original and have disconnected aux tanks. Would you replace all the lines from the tank to carb plus the carb filter and fuel line filter? Or just replace the filters? The gas smells like kerosene, but the truck will still barely run off the gas. I hope it will run better with the new tank. I am also going to do do plus and wire as points and fuel pump have been replaced. Oh yeah, what about the fuel pump it has been replace but has had the old tanks gus run through it, should I replace?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-31-2007, 10:43 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I almost forgot I replace the sending unit as well
OH! I almost forgot I replaced the sending unit as well. Getting relaxed a little quicker than I thought.
Old 05-31-2007, 11:09 PM   #3
brak
brak's Avatar
Re: Replacing tank, what else needs to go?
DRAIN THAT TANK!!! the kerosene smell you mentioned is a byproduct of the gas evaporating. it turns into a lacquer (for lack of a better word) and is not good for your carb. I would siphon out as much as possible, then fill the tank, and add a can of seafoam for good measure. It will do a good job cleaning the tank and carb.
change the filter for sure
As far as the lines go:
Personally i would inspect them, and if they are in good condition, i would just flush them out with some brake Kleen, and good 'ol air pressure...
If you can remove them from the truck, it will make the job easier, but not absolutely necessary.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 05-31-2007, 11:31 PM   #4
Bob Moore
Check the hard lines - replace if needed. Replace ALL the hoses without question.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
