Old 06-03-2007, 02:27 AM   #1
corkscrew
Why won't my alternator work?
i have tried 3 alternators and none have worked. I then tried a one wired alternator, still won't work. Am i missing somethin?
corkscrew is offline   Reply With Quote
Old 06-03-2007, 05:33 AM   #2
AR15DEFENSE
Resident Absorber
AR15DEFENSE's Avatar
Re: Why won't my alternator work?
you gotta put a belt on it. OK just kidding, some more info would probably get you a better answer
The best offense is a better DEFENSE!
AR15DEFENSE is offline   Reply With Quote
Old 06-03-2007, 07:35 AM   #3
mnunn454
mnunn454's Avatar
Are you getting voltage to the field terminal?
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 06-03-2007, 09:59 AM   #4
cdowns
cdowns's Avatar
how are you determining that the altenators aren't working??
Old 06-03-2007, 11:32 AM   #5
kwmech
Sounds like it
Get out the test light or volt meter and check the red wire which is battery. Then check the brown wire which should have voltage when you turn the key on. Start with that.
Old 06-03-2007, 11:48 AM   #6
3/4tonterror
3/4tonterror's Avatar
Your missing the G on the end of something.LOL Sounds like wiring. [VOLTAGE REGULATER MAYBE]
3/4tonterror is offline   Reply With Quote
Old 06-03-2007, 02:46 PM   #7
corkscrew
power is coming into the alternator but its not generating any and storing it
Old 06-03-2007, 03:00 PM   #8
neonlarry
neonlarry's Avatar
First off help us out, lets start by a little more than one sentence. How do you know its not generating? Internal or external regulator? Wiring changes? Give us a little more to go on.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-03-2007, 06:19 PM   #9
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
just go to advance auto and get a rebuilt alternator $16.95 and a new voltage regulator $9.95 and it should work perfect ? I buy a new alternator for my camaro about every six year's or so (JUST TAKE IT AND TRADE IT IN) the warranty on them is forever ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 06-03-2007, 07:02 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
what kind of testing have you done? how do you know it isn't charging? have you replaced the regulator? you sure it isn't just a bum battery?
Old 06-03-2007, 08:49 PM   #11
lbpd719
Zappaphile!
lbpd719's Avatar
I have to agree with everyone here, more info please, and CHECK YOUR VOLTAGE REGULATOR
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-03-2007, 10:30 PM   #12
kwmech
Then check the brown wire for voltage when you turn the key on
Old 06-03-2007, 11:58 PM   #13
sodak69c10
sodak69c10's Avatar
if you have a DVOM when you start the trucke set you meter to test dc voltage an test voltage at you b att terminals if your meter reads 13.5 -14.7 your alternator is charging, but more info could help get a quik solution
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
