Old 06-05-2007, 01:38 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
My truck squeaks like a rubber duck on roids !!!
Like the title says, my truck squeaks really really bad
It's all coming from the front end, what do I need to do to solve this
It squeaks going over bumps & it'll even squeak when you steer it while sitting still
Help !!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 06-05-2007, 06:55 AM   #2
cdowns
cdowns's Avatar
Re: My truck squeaks like a rubber duck on roids !!!
spray bomb filled with lubricant and sprayed in the general direction of squeaks sometimes helps/ then theres also whats called a grease gun
Old 06-05-2007, 07:13 AM   #3
That`s what it sounds like.Your front end needs a lube job.Time to slap some grease into those zerks.Hopefully they`re not froze up from lack of use.
Old 06-05-2007, 07:45 AM   #4
raoul.duke
Sandwich: Club
raoul.duke's Avatar
make sure your kick panel vents are closed too. Mine squeak like hell when they're open...gotta get some silicone spray on those someday....
raoul.duke is offline   Reply With Quote
Old 06-05-2007, 07:48 AM   #5
Imacarguytoo
Mine does it really bad too. I greased all but 1 fitting and it still sounds the same. So i dont know what to do.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 06-05-2007, 10:14 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I thought thats all I needed to do, I just wanted to know for sure
I'll try and get under there today & get all that I see greased
Thanks guys
Sinister
Killer
Old 06-05-2007, 11:32 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
They're 40 year old trucks? Grease all fittings. Look for loose stuff under there. If all is good, turn up the radio
That said, my truck doesn't have any squeaks at all, but she does have rattles
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-05-2007, 11:40 AM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
No radio
But I do have loud exhaust & you can still here them over that
Sinister
Killer
Old 06-05-2007, 12:55 PM   #9
mrein3
mrein3's Avatar
spray silicone lubricant at the upper A-frame bushings. Assuming it is a 2wd.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-05-2007, 01:12 PM   #10
67ChevyRedneck
Jack the truck up by the frame (not the A-arm) and check for excessive movement/wear. Your balljoints or other suspension parts could be bad.
Jesse James
Project "On a Dime"
Old 06-05-2007, 01:14 PM   #11
fun in dirt
fun in dirt's Avatar
I had a Chevelle that did the same thing... it was the A-arm bushings.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 06-05-2007, 09:16 PM   #12
dave2953
Dave's not here, man
dave2953's Avatar
Mine squeaked like yours; I just finished replacing all the front end parts and bushings and no more squeaks. Hopefully yours is a simpler fix.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-06-2007, 12:35 AM   #13
ante_up13
a suspension rebuild erased my squeaks too.
ante_up13 is offline   Reply With Quote
Old 06-06-2007, 12:53 AM   #14
jimfulco
Can you make it squeak by bouncing it? If so, get under the hood and get someone to bounce it while you try to home in on where it's coming from. Might have to get underneath the front end, also.
Spray-lube diagnosis is possible, but be sure you use the proper lube if you find something squeaking. Wouldn't want to lube steel A-frame bushings with WD-40, right? Not permanenly, anyway.
jimfulco is offline   Reply With Quote
Old 06-06-2007, 10:36 AM   #15
Jayss109
Active Member
Jayss109's Avatar
Agree with above: Upper A-Arm bushings was where my squeak was. Put the front of the truck on jack stands (Wheels off ground), this will let you get to all the zerks a little easier, and gets more grease into all those moving parts by taking the load off.
J
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 06-06-2007, 11:10 AM   #16
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks for all the tips guys
Yesterday I got under it & greased / lubed every thing I could see
It helped a lot, but it still squeaks
So I think I'll try some of the suggestions above
I really hope I don't have to rebuild me front
Sinister
Killer
Old 06-06-2007, 12:41 PM   #17
Jayss109
Active Member
Jayss109's Avatar
Mine went away after the front end rebuild, but now I can hear the hood springs (I Think?!) sqeaking. <sigh> Oh well, atleast its not nearly as loud, or annoying!!
J
Cadillac Powered
Old 06-22-2007, 10:50 PM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Well I'm gonna rebuild my front & bag it soon, so my squeaks shall be all gone soon
Sinister
Killer
Old 06-23-2007, 01:10 AM   #19
Shane
Shane's Avatar
something else to think about and check, coil springs will sometimes squeak once they become worn on the ends that go down into the lower control arm and the upper end that goes up into the crossmember.
Shane is offline   Reply With Quote
Old 06-23-2007, 06:59 AM   #20
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
scary story I was checking out a friends 69 and it squeaked when he turned the steering wheel. We found a broken bolt on his steering box and the other two were loose. He had just driven 50 miles on the interstate! Lucky man.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 06-23-2007, 07:18 AM   #21
WLPTMP
Active Member
WLPTMP's Avatar
poly bushing will squeak if they arent lubed when installed
also does it do it when turning or when u hit a bump?
WLPTMP is offline   Reply With Quote
Old 06-23-2007, 07:30 AM   #22
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Both
Sinister
Killer
