Old 06-06-2007, 09:44 AM   #1
sdailey
The Few, The Proud
sdailey's Avatar
'69 C-10 4x4 ?????
I recently purchased a '69 Chevy C-10 4x4 and I've got a few questions that I can't find an answer to yet.
My truck has 8 lug hubs. Is that common on a C-10 4x4. The vin# breakdown calls it a 2wd 1/2 ton truck. How accurate is the vin# code? The po said it was a factory 4wd truck, but who knows.
Any help would be greatly appreciated. Below is a picture of my new hobby. (Sorry about the flash)
sdailey is offline   Reply With Quote
Old 06-06-2007, 10:01 AM   #2
1969k10stepside
Re: '69 C-10 4x4 ?????
If the VIN says its a 2wd then its probably a 2wd convert.1/2 tons had 6 lugs.3/4 tons has 8 lugs.So,its probably a 2wd shortbed converted to 4wd with 3/4 ton axles.
1969k10stepside is offline   Reply With Quote
Old 06-06-2007, 10:17 AM   #3
sdailey
The Few, The Proud
sdailey's Avatar
I knew that the 8 lugs were 3/4 or 1 ton but I wasn't postiive if this was factory or not? If someone converted it they did a good job. Any negatives on having 3/4 ton axles compared to 1/2 ton axles? Also can I convert the hubs to a 5 or 6 lug?
Old 06-06-2007, 10:19 AM   #4
1969k10stepside
What rear axle and front axle does it have?You need to let us know that so we can know if they used 67-72 drive train or newer drivetrain.The front can be converted to 6 lug but the back can't,easily atleast.
Old 06-06-2007, 11:00 AM   #5
sdailey
The Few, The Proud
sdailey's Avatar
I'm not sure of the axles yet. I just picked it up yesterday. I'll do some research and get back with you. What's the best way to indentify the axles?
Old 06-06-2007, 05:59 PM   #6
CrashEd
72 chevy
CrashEd's Avatar
Its not factory the c/10 is 2wd if it was a k/10 id say thay might of just swaped rear ends. But it looks like you have a combo of diffrent trucks put togather.
Still looks good though id trade my numbers matching long bed 4x4 for it in a heart beat.
Ed
CrashEd is offline   Reply With Quote
Old 06-06-2007, 08:03 PM   #7
1969 GMC
1969 GMC's Avatar
Ed
The K10's and K20's both came from the factory with C10 and C20 emblems on the fenders...hence the confusion.
I'm guessing that it's a factory shortbed 4x4 frame, with a donor 2wd body, and the 3/4 ton axles. The hubs on your front axle say "closed knuckle drum brake D44" to me, but I could be wrong.
EDIT: to answer your other question, there was never a factory GM 1/2 ton 4x4 made with 8 lugs. The axles are definitely out of something else, and I am guessing a similar vintage K20.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-06-2007, 08:41 PM   #8
CrashEd
72 chevy
CrashEd's Avatar
Iwas going by what he said about the vin #being a c/10 2 wd 4x4 had the custom/10 and 20 badges too.
Ed
Old 06-06-2007, 08:43 PM   #9
1969k10stepside
Another thing...there was no 3/4 ton shortbeds 2wd or 4wd.
Old 06-07-2007, 07:01 AM   #10
vtblazer
vtblazer's Avatar
Sounds like a few made the one.
Nice set up if it was done correctly.
Welcome to the board, fill us in as you learn more.
vtblazer is offline   Reply With Quote
Old 06-07-2007, 07:16 AM   #11
It could be on a factory 4wd frame(1/2t short).It is possible to swap 4wd axles to a 2wd frame.Look for bolts in place of rivets at the frame mounts.Cool truck.
Old 06-07-2007, 08:13 AM   #12
sdailey
The Few, The Proud
sdailey's Avatar
I unloaded it yesterday when I got home and found out a little more about it. Like I said before according to the vin# it's a 2wd truck which I believe to be correct after looking at it closer. Also, it used to be a long wheel base. Someone has bobbed the frame to make it a short wheel base. My neighbor, who works for a body shop and is restoring a '65 Chevy, came over and looked it over with me and said whoever converted it did a good job because everything seems to match up. I'm not too up to speed on Chevy axles yet, but the rear axle was a 10 bolt. Does that mean anything to anyone? Are Chevy axles stamped for identification or do they have a tag mounted somewhere on the axle?
Thanks for all of the advice and opinions.
Old 06-07-2007, 05:17 PM   #13
msgross
msgross's Avatar
send pics of everything for an axle ID... looks nice...
8 lug axles are more "Heavy Duty" and the only downside is that the brakes are going to be pricier....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-07-2007, 09:10 PM   #14
DieselEater
DieselEater's Avatar
8 lugs and 10 bolts equals D60......
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 06-07-2007, 11:41 PM   #15
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
why would you wnat to down grade from the 3/4t rear?
the front axles are the same weather they have 6 or 8 lugs unless it is a d60 front. 77+one ton.
the rear could be either a d60, 14b sf/ff, or eaton. get us a better pic and it will be very easy.
trkklr77 is offline   Reply With Quote
Old 06-08-2007, 08:05 AM   #16
sdailey
The Few, The Proud
sdailey's Avatar
I'm not wanting to downgrade axles. I was just wondering if there was any preference on having 1/2 ton axles compared to 3/4 ton axles from a parts and reliability standpoint. Here are the pictures of my axles. I guessed Gm Corp. 10 bolt rear and Dana 44 front but that was a guess looking at pictures off the web. Someone please set me straight.
Thanks.
Old 06-08-2007, 08:27 AM   #17
msgross
msgross's Avatar
looks like a Dana44 to me and an Eaton rear... The Dana is the same as a 1/2 ton from the knuckle inboard. They have different brake brackets, spindles and hubs though. Either way I would stick with 3/4 ton gear. How many springs are in the back? Three in the front is either 1/2 ton Heavy Duty or 3/4 ton. I'm not a rear expert though, unless i'm at the beach!
The Garage:
Old 06-08-2007, 09:21 AM   #18
sdailey
The Few, The Proud
sdailey's Avatar
Mike,
I'm unsure of the leaf spring count, but I'll check later this afternoon. I did some more research on the axle and I believe you are correct on the rear end being an Eaton. Check out the link below for confirmation. What are the pros and cons of having an Eaton rear end?
http://www.blackbirdscustomtrucks.com/index5.html
Old 06-08-2007, 09:27 AM   #19
msgross
msgross's Avatar
don't know about the pros and cons, i'm sure it works fine but parts might be harder to come by. Use it for now and if you see troubles then swap later.
Hard core off-roaders prefer the Dana 60 front and 14 bolt rear combo. You're talking big bucks unless you have an old 1-ton single rear wheel truck around. What's your plans for the truck? Does it have disc brakes on the front?
The Garage:
Old 06-08-2007, 09:59 AM   #20
sdailey
The Few, The Proud
sdailey's Avatar
I might look for different axle if this one acts up at all and if I can't find parts for it. I'm going to restore it (not to factory specs of course) and just have a cool '69 4wd with a few modern updates. It has drums on the front.
Old 06-09-2007, 08:39 AM   #21
The Eaton HO52 is referred to as the corporate axle by GM.But cars had a 10-bolt so it`s clearer to not refer to the bolt count on these.There`re all Eaton rears unless they`re Dana.I found all I needed for my HO52 rebuild.Not sure about the R&P,though.I`d thinkparts are available if guys are opting for these over 14-bolts for better clearance and lighter weight with equal strength.
Old 06-09-2007, 11:23 AM   #22
trkklr77
trkklr77's Avatar
the eaton rear can be hard to get bearings for, if it fubars just drop a 14bff in and be done with it.
Old 06-09-2007, 05:51 PM   #23
earl87gta
earl87gta's Avatar
The Eaton rear is a great rear parts to rebuild it are high priced around 500. They only had a few sets of gears ether 4:10 or 4:57 the 4:57 is most likely what you have. Off road guys like them because the have more ground clearance then the 14 bolt. You can use the carries and axles from a 14bt if you ever break a set so it is rebuild able. I just traded a 14blt for one so I could have a spare. if you decide to go to disk breaks it uses the 14blt kit and is cheap to do I’m putting disks on my Eaton now and if I ever get around to it Ill post you some pics. The drum closed knuckle front I had one on my burb and just got rid of it my burb just didn’t stop that well with the big tires .As for the rear it sound like your not going to be beating on it hard so I would keep it. You can always go to a 14blt later but keep in mind if you do have the 4:57 rear and plan on keeping those gears the 14blt is going to cost you a lot more.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
