Old 06-07-2007, 03:34 PM   #1
sb69chevy
sb69chevy's Avatar
horn issues
Where are the best places to run down a horn problem. I have put power to the horn from the battery and it works. I'm guessing it's not hooked up right in the column? Right now I have a 70's camaro steering wheel, if that helps any. Thanks again. sb
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 06-07-2007, 03:47 PM   #2
67CHIP72
STOLEN
67CHIP72's Avatar
Re: horn issues
Check the relay under dash?
In Search Of
67CHIP72 is offline   Reply With Quote
Old 06-07-2007, 04:07 PM   #3
sb69chevy
sb69chevy's Avatar
Re: horn issues
No, haven't checked this. Where exactly is it? Sorry I'm dumb but learning.
Old 06-07-2007, 04:22 PM   #4
lbpd719
Zappaphile!
lbpd719's Avatar
Re: horn issues
check your fuse first. For the relay, refer to the wiring diagrams available on the board. Could also be in your turn signal switch..
Good luck
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-07-2007, 04:28 PM   #5
screamin_eagle
screamin_eagle's Avatar
Re: horn issues
you can always just lean out the window and scream profanities
screamin_eagle is offline   Reply With Quote
Old 06-07-2007, 04:33 PM   #6
sb69chevy
sb69chevy's Avatar
Re: horn issues
Too funny screamin. Trust me, I'd leave it alone, but have to get it inspected at the end of June. As far as my signals goe, I need it fixed too. signals work, but it doesn't cancel when I turn left.
Old 06-07-2007, 05:58 PM   #7
sb69chevy
sb69chevy's Avatar
Re: horn issues
Which fuse is for the horn?
Old 06-07-2007, 10:03 PM   #8
sb69chevy
sb69chevy's Avatar
Re: horn issues
Can someone point me in the right direction on the horn relay and the horn fuse? Thanks.
Old 06-07-2007, 11:49 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: horn issues
IIRC, the relay on my '72 is up under the dash, somewhere in the area above the gas pedal. Pushing your horn button should send a ground to the relay, causing it to operate (you will be able to hear it click).
The relay sends 12vdc to the horns, which are grounded through their mounting hardware.
Not sure which is your horn fuse -- it should be identified on your fuse block, though.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-08-2007, 12:35 AM   #10
jhow66
jhow66's Avatar
Re: horn issues
Here is a way to test your horn to see if it is in steering wheel.
There are 3 wires on horn relay-red -green -black
Red--power to relay
Green --takes power to horn
Black--Groung wire from steering wheel.
Remove black wire from relay --take a jumper wire and ground the relay where you removed the blacl wire. If horn blows your problem is the ground wire in steering wheel.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
