Old 06-09-2007, 06:59 PM   #1
76bonanza
76bonanza's Avatar
header repair
if you saw my previous post you saw the headers I got for free and how they cleaned up BUT there is a downside. one pipe is crushed about half the diameter near the collector (see pics) I think they are still better then the ones I have now.(very dented up) but anything I can do to help it out, it is on an unseen side so that is not a really big concern.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-09-2007, 08:01 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: header repair
I know for TPI they have different size balls you con force through the tubes to get dents out.
You might want to try something like that.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 06-09-2007, 08:28 PM   #3
nvrforgotten52
nvrforgotten52's Avatar
Re: header repair
it looks like a fairly straight run of pipe that got dented.. maybe just cut that chunk out and fit a little piece in... may be hard to weld though... just a thought
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 06-09-2007, 08:35 PM   #4
jhow66
jhow66's Avatar
Re: header repair
Heat dent with a torch and then cool it with a wet rag. This will shrink alot of it out. What's left will not make enough differance that you will be able to tell in performance.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-10-2007, 12:53 AM   #5
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: header repair
This is caused because of the header is hanging too low below the frame. Mine are like this and I've had it. I'm thinking of getting a set of headers from Early Classic. THese headers are designed for 67 to 72 trucks not a one style fits all.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 06-10-2007, 01:05 AM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: header repair
i think youd be able to cut that out and put in a new piece of pipe, and if needed you can use your crappy headers to get pieces of pipe from to fix the new ones
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-10-2007, 01:22 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: header repair
esll.
I would recomend getting hooker headers, the comp model headers hang about an inch under the frame... not the whole collector, just an inch or so is peeking out from under. on my last truck, that sucker had 500,000 mile old front springs, which would let the front bottom out, in the 4 or 5 years i drove that sucker, I never did hit the headers on the pavement. They were a little beat from being in a car, but not in that truck.
It's been a long time since I've seen any numbers, but if I remember right, the 3/4 headers aren't really worth the money... a set of ram horn manifolds flow just about as good.
Old 06-10-2007, 01:32 AM   #8
GREASEMONKEY72
Re: header repair
if you run shorty or 3/4 length headers you might aswell run manifolds, full length headers are the ones that do more than just look good
-steven
Alte Seele S.S.
Old 06-10-2007, 09:36 AM   #9
76bonanza
76bonanza's Avatar
Re: header repair
And this was caused because this truck was totalled and the front driveshaft snapped and slapped the s**t out of the header. (was on a 4x4) mine is not low enuf to drag the headers not yet anyway.
1968 c10
lowered 3" 4"
Old 06-10-2007, 10:22 AM   #10
cdowns
cdowns's Avatar
Re: header repair
you really wont notice any performance decrease by running them the way they are// to me it wouldnt be worth the effort on a driver
Old 06-10-2007, 01:23 PM   #11
AR15DEFENSE
Resident Absorber
AR15DEFENSE's Avatar
Re: header repair
I had a set on my olds that was dented like that, I put it in the vise, heated the dent up with a torch, then took a 1/2" steel rod with a slight bend in it to push the dents out from the inside. it ook a little while but when done you couldn't even tell
The best offense is a better DEFENSE!
AR15DEFENSE is offline   Reply With Quote
Old 06-10-2007, 02:04 PM   #12
76bonanza
76bonanza's Avatar
Re: header repair
thats what I was thinking also cdowns but just thought if I could do somthing cheaply might help.
1968 c10
lowered 3" 4"
