Old 06-11-2007, 07:02 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
installing a big block into a 67?????
Hi Gang,
Is there anyone here that has a true 67 1/2 truck that they have installed a big block into?
I want to find out a few things before I start working on my new 67 of which I have a 402/T400 combo that I want to install in it.
For example, what mods did you have to make for this to work? I know that the width of the top of the frame where the motor mounts go, needs to be trimmed back as the 72 bb mounts I have do not line up. Also, does the T400 fit under the cab that has a low hump or do I need to cut that out for a high hump?
Also any other tips?
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-11-2007, 07:33 PM   #2
67cst
i love summertime
67cst's Avatar
Re: installing a big block into a 67?????
all i can help with is the second part of your question, i have a low hump cab and the th400 clears the hump, its real close though because i have a lokar floor shifter and the bracket sits on top of the trans but with colum shift its not an issue whatsoever
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-11-2007, 08:56 PM   #3
Bob Moore
John - I can comment on the motor mount question. Go to the junkyard and trace the top rail of any 68 to 72 to get a pattern for the cut out. You will see that it is not very much that needs to be cut. I used 72 mounts and stock exhaust manifolds. The area of the frame where the manifolds pass gets tight without the cutout.
As I said above I used the 72 mounts, 454 with long waterpump and T-400. I did not know about the LWP vs SWP at that time. This time I am using the correct SWP and correct brackets. Only result of the LWP is very slight clearance between the fan and radiator.
I slid the automatic crossmember back to fit but only 3 of the 4 bolts on each side would fit. I did not lift the cab or redrill the frame. I have driven it since 93 with only those 3 bolts per side. IIR the ones that don't fit are the on the top. A 90 degree drill might fit but I did not have one. This time I will be able to drill for all 4.
The steering box was spaced about 1/8th inch using hardened washers and has not caused a problem.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 06-11-2007, 11:08 PM   #4
John Fabris
TOTY 2006
thanks guys... I did stop by my buddy's shop to look at a 72 short fleet that he is repainting, and I noticed the difference in the frame, so I do need to go back a make a template.
Cool to know the low cab will work with the 402. Less work for me!!!
Thanks again!
John Fabris
67 C10 SWB
Old 06-12-2007, 06:51 AM   #5
I hear it`s so close that it matters about the condition of the body mounts.I may be using a 454 in my`67 GMC project/low hump.
Old 06-12-2007, 10:31 AM   #6
John Fabris
TOTY 2006
Ya, I ordered a new mount kit and will be installing that first along with rebuilding the door hinges before I start installing the big block. My plan is to build this truck as it is, get it running, then start customizing it, then I will blow it apart and paint it....
John Fabris
67 C10 SWB
Old 06-12-2007, 01:55 PM   #7
70rs/ss
70rs/ss's Avatar
They go together without much trouble. If you use stock manifolds you will have less issues. Headers get interesting. I actually mounted the motor, and loosely bolted the headers to mark the frame and two little spots were tight, dropped the header, ground it down and put it back together. I didn't want to cut the whole top rail so I opted for the less invasive approach.
70rs/ss is offline   Reply With Quote
