Old 06-12-2007, 11:06 AM   #26
shifty
Questionable
shifty's Avatar
Re: Killers 5.3L install
Originally Posted by 69Custom View Post
Just as a warning, I am not sure if the block is the same as the SSR, but the dip stick for these engines are in the oil pan. When you swtich to the truck pan, it uses a dipstick in the block. You can locate and drill.
did you actually need to do this? I got an LS1 out of a car, tossed on a oil pan from a truck, and you must replace the oil pickup, dipstick tube, dipstick and windage tray to adapt - the OEM dipstick tube and dipstick come bundled together, same as the oil pan and windage tray - and the truck dipstick tube plopped right into the car dipstick hole without a problem - simply used a different bolt hole to mount the dipstick (alternate hole was factory provisioned and tapped into the head)
Curious if this is not the case with the SSR or TB SS engines
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-12-2007, 01:23 PM   #27
69Custom
69Custom's Avatar
No hole for the SSR motor for the dipstick to go in the oil pan. Just a blank spot. I had to drill it. The upper bolt hole was there, but no hole in the block. Luckily it is easy to drill aluminum.
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 06-12-2007, 02:07 PM   #28
shifty
Questionable
shifty's Avatar
Do the SSR and TB SS use the same block configuration and pan?
Old 06-12-2007, 03:43 PM   #29
69Custom
69Custom's Avatar
I am not sure if they use the same configuration, but I know that they both have the dipstick in the oilpan. Someone from ls1tech was saying that they had to do what I did with there trailblazer engine.
(Current Project)
2002 Saturn L200
Old 06-12-2007, 04:18 PM   #30
shifty
Questionable
shifty's Avatar
i remembered seeing a post in the past couple weeks over there about drilling the block for the TB SS pan (in fact, i replied in it asking). i completely forgot about that - either way, this is excellent information to consider for anyone doing the swap.
Old 06-12-2007, 11:17 PM   #31
68 short step
on the oil dipstick, the block on the TB has the boss machined where the dipstick would go, but isnt drilled all the way through... so get a 3/8 drill bit and drill it through (about 1/8" of material)... easy thing to do.
got the block, water pump, and acc. bracket painted and installed back on the block... starting to look like a enigne again
68 short step is offline   Reply With Quote
Old 06-13-2007, 04:56 AM   #32
killer71
killer71's Avatar
ahhh!!! Now that's what I call progress!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-13-2007, 10:40 PM   #33
68 short step
getting the engine to shine (the WP and crank pullies will need more attiton, i know, and will fix)...then ill move on to the trans.. then the'll be put back together again and then comes the wiring....
Old 06-13-2007, 10:49 PM   #34
killer71
killer71's Avatar
Dude that Rocks! Looks like you painted the intake??? The headers really bring it out!!!
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 10:54 PM   #35
72CSTC5
72CSTC5's Avatar
Damn that looks nice. Mine is on the way over!
Killer he has to do your motor so he can pay for my bill!
72CSTC5 is offline   Reply With Quote
Old 06-13-2007, 11:00 PM   #36
kyull67
kyull67's Avatar
Awesome write up so far. I think this will Definitely be FAQ worthy.
kyull67 is offline   Reply With Quote
Old 06-13-2007, 11:02 PM   #37
killer71
killer71's Avatar
Carlos, this guy could throw the towel in on the aircraft and still make a good living with this type of work. I've been talking with don for a few months and I'm still amazed at how informative, particular, and precise he is. Don't get through with his too quickly he still has a few more surprises up his sleeve on my project!
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 11:09 PM   #38
72CSTC5
72CSTC5's Avatar
What do you mean aircraft, what does he do for a living? I never asked him.
Old 06-13-2007, 11:14 PM   #39
68 short step
yea everything was disassembled and painted...i dont know why the header on the DR side looks dull, but it's not..
72cstc5..... i only know how to do 1 paint scheem, hope you like black/alumnium
Old 06-13-2007, 11:17 PM   #40
killer71
killer71's Avatar
Wink Re: Killers 5.3L install
Young Man says he keeps military aircraft in the sky (mechanic) and from the looks of his work ya gotta believe him!
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 11:18 PM   #41
68 short step
work on aircrafts..
Old 06-13-2007, 11:19 PM   #42
killer71
killer71's Avatar
Originally Posted by 68 short step View Post
work on aircrafts..
let's get personal, how old are ya Don?
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 11:21 PM   #43
72CSTC5
72CSTC5's Avatar
well glad you called him young because he looked about my age
Old 06-13-2007, 11:23 PM   #44
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
The question is what type of a/c?
I'm an Avionics Tech on F-18's .... but i have no fab skills! LOL
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 06-13-2007, 11:25 PM   #45
SCOTI
SCOTI's Avatar
What brand headers? Look like the don't hang low @ all (they look to be higher than the pan @ their lowest point).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-13-2007, 11:29 PM   #46
68 short step
23
Old 06-13-2007, 11:31 PM   #47
killer71
killer71's Avatar
Well I'm 32 and he looks younger en me!
Hey don tell em all about the headers since your the man!
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 11:33 PM   #48
killer71
killer71's Avatar
23
Dude your just a damm puppy! You got my respect tho!
R.I.P.
Killer 71
10/26/07
Old 06-13-2007, 11:44 PM   #49
68 short step
headers are for a 00 camaro/firebird brand is pacesetters.... i have a write up on what all is needed to be done and how low they hang
http://67-72chevytrucks.com/vboard/s...d.php?t=197347
Old 06-13-2007, 11:44 PM   #50
killer71
killer71's Avatar
The a/c is still up for discussion. Probably go with a fly by wire unit. Unsure about the compressor unless 68 ss has came up with a plan!
R.I.P.
Killer 71
10/26/07
