Old 12-10-2002, 05:03 PM   #1
BADA$$69
Walking accident
BADA$$69's Avatar
Unhappy 454 problem
I just got finished putting a 454 in my truck, but it will not start. I have the rotor in the right position and my wires on right (firing order 18436572). I'm getting fire to the plugs and gas in the carb but it will not even act like its going to start. The engine was in a 71 chevy truck (not original engine) I bought and it ran fine in it. All I did was took it out of the other truck and put it in mine. The engine is a 91 model. Any help will be greatly appreciated.
Laurens, SC
69 C10 W/350 & 700R4
89 Mustang GT
BADA$$69 is offline   Reply With Quote
Old 12-10-2002, 05:23 PM   #2
694X4
694X4's Avatar
Did you run #1 to tdc and the drop in dist. w/ rotor pointing to #1 plug wire? Did you even take dist. out?
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 12-10-2002, 05:24 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
Thats what I was going to say.
Make sure #1 is a Top dead center.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 12-10-2002, 05:30 PM   #4
BADA$$69
Walking accident
BADA$$69's Avatar
Yes , I had my dad put his finger over the plug hole and I bumped it over until I got tdc and I put the #1 plug wire where the rotor was pointing. I also had my dad rotate the dist. back and forth very slowly while I was turning it over and I still got nothing.
Laurens, SC
89 Mustang GT
Old 12-10-2002, 05:33 PM   #5
694X4
694X4's Avatar
is it making any noises at all except for the starter cranking? (poping, backfiring, pushing back against the starter, anything?)
work in progress
Old 12-10-2002, 05:33 PM   #6
BADA$$69
Walking accident
BADA$$69's Avatar
nothing
Laurens, SC
89 Mustang GT
Old 12-10-2002, 05:36 PM   #7
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Ran into the same problem a few weeks ago when I put in my electronic ignition.
Put the distributor in one "notch" too far. Wouldn't even start. You should also check to make sure you have your engine block grounded to the frame.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 12-10-2002, 05:38 PM   #8
694X4
694X4's Avatar
wow that is weird. I am out of ideas right now i will have to think about that over night.
work in progress
Old 12-10-2002, 05:41 PM   #9
BADA$$69
Walking accident
BADA$$69's Avatar
I am using solid motor mounts so I think that should be enough ground (I think).
Laurens, SC
89 Mustang GT
Old 12-10-2002, 05:47 PM   #10
694X4
694X4's Avatar
for ****s and giggles run a cable from the battery - post to the motor. Where is you negative run to now? Most all that I have seen have been to the alt. bracket.
work in progress
Old 12-10-2002, 05:49 PM   #11
BADA$$69
Walking accident
BADA$$69's Avatar
I am going to try that now. It is bolted to the radiator support.
Laurens, SC
89 Mustang GT
Old 12-10-2002, 05:52 PM   #12
694X4
694X4's Avatar
I think long night is right on this one. How did you check to see that you where getting spark?
work in progress
Old 12-10-2002, 05:58 PM   #13
Long Knight
When I put my motor in a while back I ran my ground from the battery to the radiator. Ended up having to go directly to the block (LOL took us a lot of beer to figure that one out!)
Long Knight
Old 12-10-2002, 06:01 PM   #14
72gmcshorty
72gmcshorty's Avatar
I had the same problem with my motor too. Turned the key and nothing at all. Just about pulled out all my hair until my friend mentioned the neutral saftery switch. Wouldn't you know it, it was loose on the steering column. Plugged it back in and motor started NO PROBLEM!!
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-10-2002, 06:24 PM   #15
BADA$$69
Walking accident
BADA$$69's Avatar
The way I checked to see if I had spark was I took the #1 wire off and connected it to plug and pressed it against the block and then turned the engine over. I grounded the block and I ran the negative battery cable to the block and still nothing.
Laurens, SC
89 Mustang GT
Old 12-10-2002, 06:36 PM   #16
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I'd suggest putting charger on ur batter for awhile to, never know if that spark aint quite enough tofire it. it happened to meonce.. good luck
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-10-2002, 06:49 PM   #17
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Sounds to me that timing is still off. Are you aligning the line on the harmonic balancer up on zero at TDC? You may have it 180 out.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 12-10-2002, 07:40 PM   #18
BADA$$69
Walking accident
BADA$$69's Avatar
Yes, I aligned the line on the harmonic balancer up on zero at TDC. I am tired of fooling with it. I guess I'll try again tomorrow. Here is a pic of the not running 454.
Laurens, SC
89 Mustang GT
Old 12-10-2002, 07:53 PM   #19
fast_dev
fast_dev's Avatar
mine did the same thing, i did the same as you with the timing and couldn't get it to start, i kept telling everyone how i did the timing and everyone said it was correct, however just because i couldn't stand it anymore, i was up for anything, my friend pulled the wires off the cap one at a time and rotated them counterclockwise one position and it started up, it didn't make sense but it ran!!! DEV.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 12-10-2002, 07:54 PM   #20
68 with 350 TPI
Sounds to me like the timming is off one way or the other.
You need...... fuel, spark, O2 , correct timming, and compression to start a engine.
I would try a little starting fluid to see if the engine even trys to start.
Old 12-11-2002, 07:39 PM   #21
BADA$$69
Walking accident
BADA$$69's Avatar
I finally got it to start. I installed a super coil on my dist. and I didn't put the rotor button in right. It wasn't sticking out of the inside of the dist. I fixed the rotor button and it fired right up.
Laurens, SC
89 Mustang GT
Old 12-11-2002, 09:13 PM   #22
694X4
694X4's Avatar
Good to hear man you had me pulling out my hair trying to figure out what was wrong. But i thought you said you had spark? Maybe not enough to get a fire.
work in progress
Old 12-12-2002, 12:09 AM   #23
chevy2racr
chevy2racr's Avatar
I like ur valve covers, they look better in a clean engine compartment than they do in mine
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 12-12-2002, 12:25 AM   #24
BADA$$69
Walking accident
BADA$$69's Avatar
Laurens, SC
89 Mustang GT
Old 12-12-2002, 12:50 AM   #25
Hooter
My other Love
Hooter's Avatar
Doh!. I remember when my 74 wouldnt start I had too many beer and forgot i had the coil un hooker. Thats good it wasn't major but what a pain!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
