Old 12-10-2002, 05:16 PM   #1
79Silv4x4
Workaholic
79Silv4x4's Avatar
Question adding second fuel tank?
My '79 came with seemingly every option but dual tanks and the single just isn't enough range these days. I'm not really interested in the Blazer tank conversion or an in bed tank (toolbox already takes up a large chunk of my space). Ideally I would like to add a factory tank to the drivers side and put in the factory dash switch and everything else. Anyone ever do this? Am I looking at a major PITA to do this or what. Any suggestions?
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 12-10-2002, 08:39 PM   #2
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
my 82 gas tank is on the drivers side. I would think that if you got hangers and straps, as well as a fuel door, you'd be half way there. You'd still need the switching assembly too.
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-10-2002, 10:07 PM   #3
Prerunner1982
Prerunner1982's Avatar
OR
OR as i found out today, you dont need the filler neck.. or the switch.... a buddy of mine converted his dual tank, dual fillers to a single filler.. he cut holes in the bottom of both tanks, used aircraft wing sealer.. (could also be welded) and ran a tube (steel braided) from one tank to the other.. gas freely goes from one tank to another.. he only uses one gauge, though he does use both pumps, if the fuel is free to flow from tank to tank. he shouldnt have too.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-10-2002, 10:27 PM   #4
J-Spec C10
J-Spec C10's Avatar
My 2 Cents:
Dude! thats scary as hell! I bet it works great, but the bottom of the tank is lower than the body already. What if the truck gets lowered, a manholecover or rock could rupture that pipe and end up spraying fuel all over the exhaust. Also, frames do twist a bit under heavy acceleration, could pull apart.
Kyle
CANADIAN CONNECTION
Old 12-10-2002, 10:35 PM   #5
Prerunner1982
he has enough slack to allow for twisting. and he is also making a skid plate to cover hose.. he plans on bagging the truck... i also made another post about this. with more info...
Old 12-12-2002, 02:59 AM   #6
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
It would be easy from a wiring stan point. Just need wiring for sending unit on tank, float level, and tank switcher valve. I have a schematic of what youwould need if you go ahead with it. Let me know.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-12-2002, 05:30 AM   #7
79Silv4x4
Workaholic
79Silv4x4's Avatar
That would be great Brandon, I talked to my local salvage yard today and he told me that I could have whatever I needed to do the swap as long as I pulled it off. I'm gonna get the tank and all of the other stuff this weekend and hopefully I can start on it next weekend!
1991 V1500 Subruban
Old 12-12-2002, 05:52 AM   #8
79BIG10
79BIG10's Avatar
Here ya go. This is for a 1 wire valve under the truck's bed in the frame rail. I don't have a 6 wire scematic. Does anyone else have that one?
Old 12-12-2002, 05:54 AM   #9
79BIG10
79BIG10's Avatar
Email me and I'll send you the larger version.
