Old 06-16-2007, 09:18 AM   #1
Lucchetti
Transmission-bell housing question
Recently I broke the Bell housing/ flywheel cover. I would like to replace the part but I don't know the size of my transmission. How do I figure this out OR how do I replace the old part without knowing the transmission size?
History-I just bought a 1968 c10 short bed. When the kid sold it to me he said it had a 283 engine, and that's about all I know. (I’m not even sure that is correct.) As you can tell I'm a little green at this but I do plan to learn my way around and get this truck rebuilt. I appreciate any help on the bell housing questions for now.....thanks
Lucchetti is offline   Reply With Quote
Old 06-16-2007, 09:32 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Transmission-bell housing question
You came to the right place for info.The 68 will have a bellhousing thatbolts to the frame on either side.IIRC all of them are the same.If you subscribe to the BB there are classifieds where you can look.I'm sure someone has a bellhousing that will fit.
BTW WELCOME to the besyt resource you will find for info on these trucks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-16-2007, 09:42 AM   #3
Green Machine
Green Machine's Avatar
Be sure to check the size of the bearing retainer hole at the back of the bell, IIRC 67 and earlier was smaller and 68 up had the larger hole, someone here will remember the dimensions. Check the for sale thread, threre were two for sale on the same thread a few days ago, from the pics it kind of looked like one ws small hole and the other large hole.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-17-2007, 06:35 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
'67 trucks with both 3-speed Saginaw and 4-speed SM420 used a bellhousing with a 4-9/16" diameter pilot bearing hole [GM p/n:3815891]. '68 [and later] 4-speed trucks used a bellhousing with a 5-1/8" opening [GM p/n:3925505].
Is it a 3-speed (shifter on column) or a 4-on-the floor? If it's a 4-on-the-floor, is Reverse to left [toward you] or right [away from you]? If to the left it's a 420, if to the right it's a 465.
The bell housing is the heavy cast iron part on top. The flywheel cover is the sheetmetal guard on the bottom. Don't lose it, they're hard to get now. Did both break?
Old 06-17-2007, 08:21 AM   #5
crazy longhorn
Fabricate till you "puke"
The early truck & car bell are 4.684 dia hole(4 11/16). Try Jegs, & look up Lakewood bells, it gives dimentions). The 68 up truck has a 5.126 hole, so just a thought......if you are running a Saginaw 3 spd(7 bolt sidecover), you can swap the front bearing retainer tween the car or truck 3 spd trans(saginaw), & use either bell.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-17-2007, 09:47 AM   #6
Lucchetti
Awesom, thank you. It's a 3 speed on the column. The only part I broke was the bell housing--it was plastic.
Old 06-17-2007, 12:07 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
can you provide a photo of what you broke? I'm thinking we have termanologymixed up here.
Old 06-18-2007, 06:20 AM   #8
'68OrangeSunshine
My measurements were done in the field, not out of a book.
Does the post-'68 Saginaw have the larger 5-1/8" diameter?
Old 06-18-2007, 10:19 AM   #9
crazy longhorn
I have also measured the bell in the "field"(with dial calipers)..... I run a 66 truck bell on my longhorn, fitted with a Richmond 6 speed(car style bearing retainer, & 26 spline input shaft), & it all fits the early truck bell The 68 up saginaws(truck), do have the 5 1/8" bearing retainer, but the retainer can be swapped tween the car or truck sag 3 spds, as well as the sag 4 spd. Im not sure what plastic pc is broken tho? L
Old 06-20-2007, 07:54 PM   #10
'68OrangeSunshine
I have also measured the bell in the "field"(with dial calipers)..... L
OK. I used a 25' tape measure. Real hi tech.
