Old 06-16-2007, 05:53 PM   #1
superman3405
Junior Member
superman3405's Avatar
A/c
Guys, i put a new compressor on the truck last weekened to get it cooled off inside. The problem is it is not cooling, just blowing. Any suggestions on what I should trouble shoot?
Don
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 06-16-2007, 06:12 PM   #2
1970shortbed
Active Member
Re: A/c
im sure u rechaged the system with new freon after the new parts but its a thought because i forgot once lol
1970shortbed is offline   Reply With Quote
Old 06-16-2007, 06:19 PM   #3
Blue4x4
Blue4x4's Avatar
Re: A/c
Did you do a leak check with nitrogen and pull a vacuum to 300 microns?
Blue4x4 is offline   Reply With Quote
Old 06-16-2007, 09:31 PM   #4
superman3405
Junior Member
Re: A/c
yeah new freon, and no leaks....
350/350TH
Old 06-16-2007, 09:49 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: A/c
So is the compressor clutch engaging?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-16-2007, 09:56 PM   #6
clay68c10
clay68c10's Avatar
Re: A/c
Recirc flaps closing? Is it even a little bit cool? What kind of pressures are you seeing?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-17-2007, 10:34 AM   #7
1970shortbed
Active Member
Re: A/c
yesterday in my truck it seemed to just blow and i wiggled the switch back and forth and bingo it was working good again
i think it was just stuck in the middle as i was just playing wit hthe switches a few minutes prior
Old 06-17-2007, 11:19 AM   #8
Blue4x4
Blue4x4's Avatar
Re: A/c
glad to hear it's working again.
Old 06-20-2007, 11:29 PM   #9
Andy4639
Old member
Andy4639's Avatar
Re: A/c
Check the push button on the back side of the vent at the center of the floor board it's got to hit the switch when you have the A/C on. The cable may not be adjusted just right.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
