Old 06-17-2007, 11:18 PM   #1
Rogue Willie
Rogue Willie's Avatar
‘69 LS1 C-10 Pace Truck build
Why a pace truck? Because I’m going to paint it like a ‘69 Pace car Camaro, but that is a long ways off. I originally got this truck around ’90 or ’91 for $1500. By ’97 I had put nearly 100k on it and used (abused) it well. During that time the original 350 had blown and I put a junkyard 305 in it. In late ’97 I was told I was getting a divorce and the ex ended up with the truck. About 3 ½ years ago she gave it back to me after it had sat around for awhile because it wouldn’t run. I got it to run and got it moved to my backyard where it had been sitting ever since. I finally got to the point where I had the finances (no wives, no child support, and no car payments) to rebuild my truck.
You can see by the pictures the progress to date. It’s got a 3 ½ drop in the front with a 4 in the back. I may drop the rear some more after I get the body back on and see how it sets. The motor and trans is out of a ’02 Camaro that had 40k on it. The rear has been rebuilt with 3:73s, an Eaton posi and a 5 lug conversion. Future plans include aftermarket A/C, one piece windows (somebody please tell us how the no triangle thing is going), bench seat out of a late model truck, Gaylord fiberglass tonneau cover, stock bumpers, cruise control, and white paint with orange rally stripes.
I started 6 months ago and have a long way to go. Stay tuned for future updates. I’ve been following the other LS1 builds and will probably be asking you guys question. On the other hand, if any one has questions please ask. I’ll post this over at LS1Tech as well.
69 C-10 in progress
Rogue Willie is offline   Reply With Quote
Old 06-17-2007, 11:20 PM   #2
msgross
msgross's Avatar
Re: ‘69 LS1 C-10 Pace Truck build
that will be sweet! Might wanna post a pic of the pace car so guys know the scheme.... good luck
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-17-2007, 11:23 PM   #3
Rogue Willie
more pics
69 C-10 in progress
Old 06-17-2007, 11:25 PM   #4
bills67
bills67's Avatar
Sweet!! Can't wait to see pics when finished.
bills67 is offline   Reply With Quote
Old 06-17-2007, 11:31 PM   #5
shifty
Questionable
shifty's Avatar
you probably already have this, but ....
Link to several other swap threads:
http://67-72chevytrucks.com/vboard/s...&postcount=125
Link to my 15-page buildup thread with pics:
http://www.ls1tech.com/forums/showthread.php?t=370781
With that said - a lot of the guys are swapping in truck engines and not actual LS1's. I put an actual LS1 into my truck, so I probably have a lot of info to share with you specific to your particular swap - see that last thread link.
Meanwhile, three questions for you:
1) did you notch your frame to clear the A/C compressor?
2) Did you notch your frame to clear the '02 stock manifolds - and if not, how'd you pull that one off?
3) What engine mounts did you use? ECE?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-17-2007, 11:44 PM   #6
blaznhot_23
blaznhot_23's Avatar
good questions ^^^
subscribed
blaznhot_23 is offline   Reply With Quote
Old 06-17-2007, 11:48 PM   #7
krue
Designated A-hole!
krue's Avatar
I love the looks of that engine in there, got me thinking......
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-18-2007, 07:37 AM   #8
rlm316
rlm316's Avatar
Looks great, nice detail! Quick question, whose tie rod adjusting sleeves are those? Looks alot nicer than the stock, More like a real turnbuckle, should work great!
rlm316 is offline   Reply With Quote
Old 06-18-2007, 09:51 AM   #9
killer71
killer71's Avatar
who did you get the disc brake set up from? Are you gonna go rear disc?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-18-2007, 12:36 PM   #10
Rogue Willie
Thanks for the encouraging words.
Shifty, I've been following your threads and that is what lead me to go with the LS1. I did notch the frame for the a/c compressor. I also notched the stock engine mount towers to clear the hose connection and to clear the egr boss on the manifold. I have not clearanced the frame for the exhaust manifold as of yet but it only needs a little bit. I used the motor mount adapter plates that are available from many sources and moved the towers back about an inch to gain oil pan clearance. I'll post a couple close up pics tonight.
The disc brake conversion including tie rod adjusters came from Classic Performance Parts.
69 C-10 in progress
Old 06-18-2007, 05:39 PM   #11
71tahoe
71tahoe's Avatar
In post #3, what hitch are you using. It looks a lot like my Shelton that I didn't think I could use with my blazer tank. Did you have any problems and what solutions did you come up with?
71tahoe is offline   Reply With Quote
Old 06-18-2007, 06:11 PM   #12
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Cool Re: ‘69 LS1 C-10 Pace Truck build
GR8 Idea on the 69' Pace Truck!!
Progress is looking good to.
I posted a couple pic's that I had of the 1969 Camaro Pace Car to give guys an Idea of what you are shooting for Like msgross mentioned.
I'll say it again I think it's a GR8 IDEA!!!
Are you going to do the interior in the 69' pace car style also?
I have always liked the way the 69' pace car looks and I think the 69 pace truck will be just as cool. I'm subscribing to your build.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-18-2007, 06:22 PM   #13
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Subscribed
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-18-2007, 10:17 PM   #14
Rogue Willie
Here's a pic of the frame clearance around the a/c compressor.
The hitch came from ECE. The only issues I had with the install were a little grinding on the forward most part for a bolt clearance and trying to get to the nuts inside the frame rails and next to the gas tank.
I'm going to do the interior in black with possibly white houndstooth inserts in the seats. The gauges will be white faced with a black dash.
Thanks for the PaceCar pics. I'm not going to run a cowl induction hood but it will have the fiberglass cover on the bed. I just like the idea of the orange rally strips on a white base.
69 C-10 in progress
Old 06-19-2007, 08:12 AM   #15
jkade
jkade's Avatar
Now that's tighter than dick's hat band Good work and I see now what I will have to do when I get to that point.
jkade is offline   Reply With Quote
Old 06-19-2007, 08:28 AM   #16
Billla
Billla's Avatar
Y'know, it almost looks like some headers that go out and over the frame rail would be a better deal - kinda like the Hooker side pipe headers for C3 'Vettes...?
Billla is offline   Reply With Quote
Old 12-17-2012, 02:24 PM   #17
1970 C10 MJW
1970 C10 MJW's Avatar
what ever happened with this build???
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 12-17-2012, 03:40 PM   #18
Rogue Willie
The chassis is mostly done. Most of the metal work on the cab is done. I put it aside while I worked on a couple of other projects, a '28 roadster rat road and a custom chopper. I'll get back to it one of these days.
69 C-10 in progress
Old 09-15-2014, 06:04 AM   #19
1970C20L9H
any updates?
1970C20L9H is offline   Reply With Quote
Old 09-15-2014, 12:16 PM   #20
68shortwide
68shortwide's Avatar
X2
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 09-15-2014, 02:30 PM   #21
Andy4639
Old member
Andy4639's Avatar
Talking Re: ‘69 LS1 C-10 Pace Truck build
Please tell me your not going to put the Camaro front clip on this truck...please!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-16-2014, 03:55 PM   #22
Rogue Willie
No updates, it's still sitting in the garage next to the chopper project which is now behind the 06 duramax salvage rebuild.
69 C-10 in progress
Old 09-17-2014, 08:58 PM   #23
Z10
Z10's Avatar
Here's a couple of pics of a pace truck and one of my 69 Z10 Pace Coupe.
I think it will look great!
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 09-18-2014, 12:45 PM   #24
kitsbeach
kitsbeach's Avatar
That pace truck is pretty cool..!
And the Camaro too..! I had a white 69 SS396 back in the day. shouldn't have sold it.!
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 09-18-2014, 04:33 PM   #25
Heavymetl
That truck with the Camaro front end isn't my style AT ALL.
Reminds me of this internet classic abomination...
Heavymetl is offline   Reply With Quote
