Old 06-19-2007, 01:39 PM   #1
mvpco
72 rear Air hoses need info please
Hi All!
I am looking for the rear air hoses for a 72 burb.
Does anybody have the part numbers or lengths and sizes???
I need to replace them and would like to get that info to see if I can get them made locally or if I will have to order them
Jeff Smith
Pensacola
Jeff Smith
Pensacola, FL
mvpco@yahoo.com
mvpco is offline   Reply With Quote
Old 06-19-2007, 01:51 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 72 rear Air hoses need info please
Jeff,
Your local NAPA store should be able to make them for you.
Rob
Hart_Rod is offline   Reply With Quote
Old 06-26-2007, 10:14 PM   #3
mvpco
was 72 rear Air hoses, now AC info or thoughts please
Just a note:
I found out it was not the hoses at all!!! It was the R134 adapter for the low side, it had a split oil ring...wow!! i changed it out and no more pressure loss and it held a vacuum...sweeeet!
I have about 46 lbs pressure and will lower it after running a few days.
I changed out the compressor and dryer, Air is working but needs to be colder... I shut the hot water flow off just in case till I rule out everything.
I dont know about VOA? Valve, when they did the R134 change over on this burb a few years ago, if they adjusted that. I remember 2 years ago reading on the list about the pressure adjustment on that from R12 to R134. dont know if that will help in lower the temp alittle bit more.
The rear air seems colder than the front???
Things known:
new compressor and clutch assy.
new dryer
new R134 & oil charge installed about 32 oz??(about 2, 18oz cans) front and rear air 1972 burb
hot water shut off to inside cab
flap all the way flipped for air flow to go through evap. side
46 psi on low side(should I lower it or wait and run it for a few days then bleed it off?)
any thoughts???????
Jeff Smith
Pensacola, FL
Jeff Smith
Pensacola, FL
mvpco@yahoo.com
