Old 06-20-2007, 01:53 AM   #1
70 GMC Trucker
70 GMC Trucker's Avatar
Help converting to power steering
I have 70 CMC 1/2 ton and am wondering what year of GMC/ Chevy i can use for a power steering conversion. My truck had a six but has been converted to a 350 ( not sure what year ) but it does have the threaded holes to support the bracket. Also what do I need ( pump, lines, gearbox and bracket ) anything else. Any info would be great.
70 GMC Trucker is offline   Reply With Quote
Old 06-20-2007, 10:48 AM   #2
Southedisto
River life......
Southedisto's Avatar
Re: Help converting to power steering
You are going to need a different crank/waterpump pulley setup also.
Southedisto is offline   Reply With Quote
Old 06-20-2007, 01:15 PM   #3
5150
C10 Club Tennessee
5150's Avatar
You can get a power steering setup off pretty much any 73-87 truck. Just get the gear box and pitman arm. You can get the power steering pressure line and the return line also, but I'd recommend getting those new. Get the pump and brackets obviously
It also would be a good time to collapse the steering column if you need a little more gut room like me.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-20-2007, 03:01 PM   #4
dmsteele92831
Also if you get a 80's gearbox, get the pump to match and make sure the gearbox and pitman arm are off a 3/4 or 1 ton (1/2 ton won't work)
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 06-20-2007, 03:49 PM   #5
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I used a gearbox from our trucks. (junk yard, took old hoses too)
80's model pump from another truck I had. (it was thrown together with who knows what by the PO)
New high-pressure hose from AZ for a 71. Got a brass fitting for the 71 hose to go on the 80's pump. (I think... that's what it looks like. It's been a long time sense I did this conversion.
Water pump pulley is from an 85 El Camino I had. (probably get it from anything)
Made some high dollar custom bracket for the pump because I don't have factory manifolds.
Oh, cut the driver fender well so the hoses can come out of the gearbox. Non power steering inner fenders are different then power equipped trucks. Or you could find one for power.
LOW DOUGH is offline   Reply With Quote
Old 06-20-2007, 04:53 PM   #6
Texasduffer
Thumbs up Re: Help converting to power steering
You didn't say if you were trying for the cheapest route or the easiest route. I went the 'easy' route and called CPP and got the whole setup from them. It works perfectly and couldn't have been easier. My two cents...
Texasduffer is offline   Reply With Quote
