Old 12-11-2002, 08:28 PM   #1
MidnightBlues
Question ventwindowseal-Gchemist
As I remember correctly you replaced the vent window seals a while ago??
I'm working on this now,and have a question:
The old seal was a 2 piece seal and had metal clips on the rear seal to attach it to the frame.The new one(oem) is a 1 piece seal without metal clips.
Am I supposed to glue the rear part to the frame??
*Andre*
1984 C10 SWB, 350/700R4
MidnightBlues is offline   Reply With Quote
Old 12-11-2002, 11:30 PM   #2
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
will the seals get rid of the whistling noise when I drive? if so, where are the seals available?
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-12-2002, 02:11 PM   #3
PHOENIX
I need to fix my seals too.
Yes J-Spec the truck should not have any whistling sound if everything is good.
TIP:
When ever having a window replaced by a perfessional. Always test his work. Take your truck for a ride with all the windows down, then with all the windows up. That way you can figure out if youll have any problems.
I had a wing window replaced and ever sense it has whistled. If you crack one of your larger windows it will stop the whistling. But now you have a window open. I guess you have to choose whats worse.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-12-2002, 03:45 PM   #4
J-Spec C10
J-Spec C10's Avatar
its minus 10 celcius here, I'm not driving anywhere with my windows down!!
Kyle
CANADIAN CONNECTION
