Old 06-22-2007, 12:49 AM   #1
jimmyj
Starter solenoid
Any tips on how to get to the starter solenoid without taking the exhaust pipe and starter out first? I have a '72 Chevy C20 Super Cheyenne. It looks like I have to get through those before I can switch out the solenoid, but I figured someone might have done it an easier way -- or with a special go-go-gadget solenoid-removing tool or whatever.
Thanks. I really don't want to have to remove all that just to switch out the solenoid!
jimmyj is offline   Reply With Quote
Old 06-22-2007, 01:30 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Starter solenoid
I've always just pulled the entire starter, shouldn't have to remove anything else.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-22-2007, 01:45 AM   #3
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Same as Krue, drop the starter and change solonoid. I would think that it would be easier to work on the starter out of the truck.
How are your pipes installed that you have to remove them?
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 06-22-2007, 02:34 AM   #4
dave2953
Dave's not here, man
dave2953's Avatar
If he still has the y-pipe he probably has to remove it. I had to take mine off when I did anything with the starter before I switched to duals.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-22-2007, 09:27 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
What problem are you having? Solenoids rarely go bad themselves. Usually it's a wiring problem or bad grounds. Heat soak is often blamed on the solenoids when the starter won't turn after the engine is warm. Tell us more and maybe we can help. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-25-2007, 09:05 AM   #6
jimmyj
Exactly what you said: it doesn't turn over after it's been running for a while. And actually, lately, it won't turn over at all, so a buddy of mine figures the solenoid is finally dead. New battery, new starter, new alternator .. what could be going wrong, if it's not the solenoid??
Thanks for your suggestions.
Old 06-25-2007, 09:36 AM   #7
Chevyholic
Will it run today?
Chevyholic's Avatar
This is pretty common, as a matter of fact had the same issue with my 66' and then with my 71'. I finally purchased a remote solenoid and purchased a heat shield for my starter. I haven't had any problems since. I want to say the remote solenoid ran about $20-30.00 bucks, well worth it. I no longer cringe every time I turn the key.
Also, do a search for remote solenoid and you will find numerous install guides.
Cheers,
David
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 06-25-2007, 09:59 AM   #8
rlm316
rlm316's Avatar
Sounds to me like you finally burned out the starter motor trying to start it while it was dragging, or you burned up the wiring. Either way the starter would need to come down. If you have a voltmeter or a 12v test light see if you have voltage at the starter. If you do then try to jump out the solonoid and see if the starter will turn. When you are all done fixing the starter, check your ignition timing.
rlm316 is offline   Reply With Quote
Old 06-25-2007, 04:12 PM   #9
Ackattack
Ackattack's Avatar
I would recommend getting a remote starter solenoid regardless if you have to replace the starter. Saves yourself a lot of headaches in the long run.
Ackattack is offline   Reply With Quote
Old 06-25-2007, 04:35 PM   #10
cdowns
cdowns's Avatar
before throwing parts at it i'd suggest a piece of 80grit sandpaper and cleaning up the grounds to the frame and engine block
Old 06-25-2007, 05:05 PM   #11
Ackattack
Ackattack's Avatar
Very true....find my thread from the other day about my motorhome
