06-23-2007, 08:50 PM | #1 |
It's the air up here
What about 1 ton DRW 14 bolts?
Will the 14 bolt DRW axle fit our trucks for SRW? Or are the DRW axels wider over all? I am talking about the rear axel, not the dana 60 front.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
06-24-2007, 12:30 AM | #2 |
Re: What about 1 ton DRW 14 bolts?
they make 2 different 14 bolt drw rears.
1. cab & chassis 2. the widest one is from a true dually pickup. the outside tires on both sides will stickout past the side of the truck the width of the tire on both sides. i have both and fixin to start building a c30 157" wb cummind 6bt, spicer 5 spd. od. with a 14 bolt and 3.21 gears, 19.5 tires. aluminum flat bed. bob in tn.
I BELIEVE IN JOHN 3:16 |
06-24-2007, 05:11 AM | #3 |
Bob I look forward to your build.
My 14bolt FF is about 3" narrower than my 44 front as measured at the wheel mounting surfaces. I've been told that it could be from a narrow utility bodied dually. I did have to relocate the spring perches. My 68 rides a little high, and wheel clearance hasn't been a factor.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
06-24-2007, 11:49 AM | #4 | |
06-24-2007, 12:26 PM | #5 |
Well, Whoop-dee-do!
I'm curious to know EXACTLY where you find a wide 14. I'm assuming it is from something '88 or newer?
I'm a 3.21 fan too- but I doubt my 454 pulls them as good as a Cummins
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
06-24-2007, 02:11 PM | #6 | |
One thing to watch for on the newer 14 bolts is if they have slip on drums or not. If you want rear discs, this can open up a whole new can of worms.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
06-24-2007, 07:50 PM | #7 |
Ojoe Has A Couple Dana 70hd,s For A Real Good Price And There The Wide Ones.... As Far As 14 Bolt With Rear Disc Brakes There The Metric Bolt Pattern For The Wheels. Price For Wide 14 Blts Is 200.00 And Up To 1500.00. I Looked For 4 Months To Find A Low Milage Wide 14 Reasonable. Good Luck. Thanks Kw Mech. For Hookin Me Up With The Gear Guy. I,am Gonna Call Him And Get A Second Set.
Bob Bob
06-25-2007, 11:41 AM | #8 | |
Around here, I trip over piles of 14 bolts at every junkyard. The wide DRW truck axles arent as common, but the van 14 bolts are. Must be a regional thing.
06-25-2007, 01:38 PM | #9 |
Location: vacaville ca, because it as far from indy as i can be
drw truck 14bff have shoter perch width and wms. the perches are at 40" and there is not much room to widen them. the also have a 63" wms. use the same axle shafts as the srw but the hub is flanged closer to the center of the axle.
it is infinatly easier to wait and get a srw then to hassle with the drw. |
