Old 06-24-2007, 04:35 AM   #1
Mudder
Mudder's Avatar
Very short trip.............
Well Friday I had to return home from St Louis on my way to Springfield IL. Al least I didn't have to be broken down on the side of the interstate in St Louis during Friday rush hour. Was getting hot enough and wouldn't cool back down that it was missing really bad. I adjusted the carb back to the origninal adjustments and went to a friends house. (Was very lean). Always make sure somone knows what they are doing before you let them turn screws on your Holley. Also found that the radiator cap was not holding any kind of pressure. Truck ran great coming the rest of the way home but it had cooled off pretty much. I will be testing it out the next few days to see if I repeat what had happened. Can't really believe that a cap would not allow things to cool off going down the Hwy.
Mudder is offline   Reply With Quote
Old 06-24-2007, 01:35 PM   #2
1969k10stepside
Re: Very short trip.............
That sucks Mudder.Hopefully you will make it next year
1969k10stepside is offline   Reply With Quote
Old 06-24-2007, 02:17 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Damn that does sux. I hope you can get everything squared away.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-24-2007, 06:59 PM   #4
OrrieG
OrrieG's Avatar
Years ago I worked at a gas station in Phoenix while going to school. Most of the cars that were overheating had some type of compromise to the cooling pressue system (cap seal gone, hose hole, etc.). The pressure in the system allows it to run at a higher temp without boiling. If air is allowed in the system and it can't maintain the pressure, boiling point falls. First thing we did was to get it cooled down, then ran a pressure check on the cap and system to find the problem. Usually a hose or cap, sometimes we found it was blown intake maniford or head gasket. This was in the mid-70's when things were relatively simple, no electronics etc. Glad you found the problem, you might want to check the timing, it will make a difference too.
Old 06-25-2007, 12:56 AM   #5
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Just another dumb thing that happened to me,bad radiator cap was my problem on a 76 3/4 350.The old truck run fine until a trip on I29 to St Joe,it started getting hot and i would pull over and it took a while but would cool down and after three times of this it was getting old.Finally i held the throttle at highway speeds and watched the bottom hose suck shut.shut it down and after a little cooling time dug thru the tool box and found a roll of wire.
Wound the wire inside the hose and filled it with ditch water.Made the rest of the trip with out a hitch but found the radiator cap at fault..........As far as I know the wire is still in it
powerdriver 1958 is offline   Reply With Quote
