Old 06-25-2007, 10:25 PM   #101
killer71
killer71's Avatar
Re: Killers 5.3L install
Originally Posted by Hart_Rod View Post
I'm confused (that happens a lot ). I thought you were using the factory engine harness or was that just on yours?
this is just the fuse relay box it's aftermarket. We are still using the factory wiring harness though. Make sense?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-25-2007, 10:48 PM   #102
shifty
Questionable
shifty's Avatar
Originally Posted by 68 short step View Post
"in place of your old fuse block"?, are you talking about your stock glass style fuse block under the dash?
yep, been thinking about taking the glass style out, and using the add'l circuits on the SA-1000 to handle radio, cig lighter, tail/head lights, blinkers, dash gauges, dome light, and ... i mean, what else is there really? ignition, wipers, wiper motor .... in all honesty, there is so very little, it's just a matter of tracing wires to the bulkhead, tapping them into the SA-1000, then running the outbound circuit properly. sounds simple in theory, but i'm probably grossly oversimplifying (hence why i haven't worked on it in forever.
i just got screwed though, AutoMeter is seriously slacking, my gas and speed gauges have been backordered everywhere for damn near 7 weeks now. i'm going nuts, Jegs pushed it back till end of this month, like they've done four other times (so has Summit and every other place, so i know it's not their fault)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-25-2007, 10:57 PM   #103
Hart_Rod
Hart_Rod's Avatar
Shifty, not to get in your knickers, but.... you might as well replace all the wiring. By the time you do what your talking about, it wouldn't take that much more to finish the job. With the time and effort that you've put into your truck, I would hate to see it catch fire do to some 40 year old wiring. Just my .02.
Hart_Rod is offline   Reply With Quote
Old 06-25-2007, 11:08 PM   #104
68 short step
fault)
no, thats way too mcuh work, and also the sa-1000 does'nt have near enought circuits to support the interior.... things your forgetting about is the steering column ( turn signals, ignition switch, temp controls, all the guages, radio, front lights, rear lights, etc.... the sa-1000 doesnt nearly have enough circuits..
68 short step is offline   Reply With Quote
Old 06-25-2007, 11:34 PM   #105
killer71
killer71's Avatar
R.I.P.
Killer 71
10/26/07
Old 06-26-2007, 08:14 AM   #106
69Custom
69Custom's Avatar
68 short step- how much would you charge to rewire a harness? If you are interested in doing another one.
Jeremy
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 06-26-2007, 09:26 AM   #107
shifty
Questionable
shifty's Avatar
Ah, you are correct about that ... only 6 ING and 2 BATT circuits :\ But in the instructions of the SA-1000 it says you can create as many circuits as it will house fuses (I think it is either 16, 25 or ??? would need to look at instructions again)
maybe this is the time I need to start thinking about getting one of those 'hot rod' kits like the Highway 15 or Highway 22 that AAW sells (member Musclerodz sells them)
Rob - my wiring is actually in pretty damned good shape, amazingly. but i am pretty adamant about ditching the stock harness, still. I think the only part I'll use is the headlight portion of the stock harness, and that will be running off relays.
i like the idea of mounting the SA-1000 kit on the rad support, then using a harness inside for the other stuff. Dunno what I'll do at this point.
Old 06-28-2007, 09:39 PM   #108
68 short step
here's the finished rad. support
body work sucks.......
Old 06-28-2007, 09:51 PM   #109
hyde
hyde's Avatar
Nice
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
Old 06-28-2007, 10:23 PM   #110
killer71
killer71's Avatar
"bodywork sucks" Man are you kidding looks good from over here in louisiana!
R.I.P.
Killer 71
10/26/07
Old 06-28-2007, 11:16 PM   #111
shifty
Questionable
shifty's Avatar
it's beautiful. You can paint my rad support any time you want
Old 06-28-2007, 11:17 PM   #112
shifty
Questionable
shifty's Avatar
ps - i'd buy one of those any day
Old 07-01-2007, 07:41 PM   #113
68 short step
made a little headway today... got the cab stripped down, took out the wiring, glovebox and door, a/c controls, a/c ducting and air defusers, guage panel.. all in preperation for the cab to come off the frame... also locaed and drilled a few holes for the engine and trans. computer moduals.. PS i tried to get the most cluttered pic of the inside of the cab, just so killer71 will have a good night sleep all that stuff is neatly stacked inside the garage now... also most the interior stuff ( auto/ tilt steering column, brand new (looking)wiring,etc... ) will be replaced, so ask killer71 if you need something. he just might sell it to ya, and EVERYTHING is in great shape..
Old 07-01-2007, 09:34 PM   #114
killer71
killer71's Avatar
Ahh, I think I'm gonna be sick! Na just kidding, man o man are things in disarray are what? Keep up the good work!
R.I.P.
Killer 71
10/26/07
Old 07-03-2007, 11:02 PM   #115
68 short step
pullin a all nighter again.. i finally recieved the ECM pins to re-pin the computer, so i needed the engine in the truck to see how far back to make the connections to the computer...the only snafu i ran into was the the stock trailblazer P/S pump resovoir hits the frame, so what the plan is, is to switch to a truck style resovoir... other then that everything fits in there nicely...
Old 07-03-2007, 11:15 PM   #116
Hart_Rod
Hart_Rod's Avatar
I'll be waiting for updates throughout the night, .
Old 07-03-2007, 11:42 PM   #117
BigTex
Wow, that is one very clean truck. Killer, you are going to love the conversion. Any performance upgrades to the motor?
Richard
1970 Chevy (growing pile of parts)
2003 Silverado SS
BigTex is offline   Reply With Quote
Old 07-04-2007, 12:17 AM   #118
68 short step
the performance upgrades so far are
- long tube headers
- cold air intake
- custom puter tune ( gonna get it dyno tuned, for the optimum performance)
Old 07-04-2007, 09:39 AM   #119
72CSTC5
72CSTC5's Avatar
Don she is looking good. The core support came out so nice I am bringing your truck back to you! LOL!!
Killer it is looking good man. I have my 5.3 with trans sitting in the garage. Picked it up a couple of weeks ago. I think I will drive my truck this year and then tear it back down again next year for the motor swap.
72CSTC5 is offline   Reply With Quote
Old 07-06-2007, 07:01 PM   #120
68 short step
finally getting some work done... got the trans cleaned and painted, this is the final piece i needed to get done to complete the wiring harness.. when its completely dry i'll mate the engine and trans back together and make the harness.... then the drivetrain (minus the driveshaft) will be complete...the frame will get attention next..
heres what i started with (the good pics got deleted, sorry)
and heres what we've got now.
Old 07-09-2007, 10:39 PM   #121
BigTex
OK, spill the beans, what did you paint that transmission with? Did you sand it down before the paint? You can barely see any of the aluminum texture. It looks great!
Richard
2003 Silverado SS
Old 07-09-2007, 10:58 PM   #122
68 short step
the paint is the same as the engine HIGH TEMP ALUMINUM ENGINE PAINT... yes i sanded it down then scotch brighted it, to get that smooth look..altho nobody will see it..we'll all know it looks good
Old 07-10-2007, 07:08 AM   #123
killer71
killer71's Avatar
And look good it does!
R.I.P.
Killer 71
10/26/07
Old 07-10-2007, 07:23 AM   #124
msgross
msgross's Avatar
nice project... What is the budget on this kind of swap? From start to finish?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-10-2007, 08:51 AM   #125
killer71
killer71's Avatar
Well we ain't through yet but I'm anticipating up around $13,500. Initally we figured around $8000, but hang around and you'll see why!
R.I.P.
Killer 71
10/26/07
