early 70's large hub look
I'm installing 77 3/4 axles in my 67 3/4 ton but the hubs don't look as big diameter as the earlyer 70's year hubs , will the early hubs fit on thes axles (if I find some in the future), I like the beefier look of the early 70's, thanks.
65 tripower conv 4spd gto, 66gto, 67 gto 65 lemans conv 4spd 69 firebird conv. 67 c20 4x4 |
Re: early 70's large hub look
the 67 was closed knuckle, right? If so then I doubt it.... Put a dana60 under it and you might be good...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
The chrome-rimmed/blue centered lock-outs were used from 69-75 and won`t fit those axles/hubs.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-26-2007 at 10:48 PM. |
72 chevy
![]() Join Date: Jan 2007
You would have to change out the spindel and the out side shaft but it will bolt to the newer knuckel.
Ed |
It's the air up here
Your talking about the large spicer hub, right?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
72 chevy
I think he is talking about going from internal to external lockouts and wanting to change it all from the knuckel out if he finds some.
Ed |
The smaller internal style lockouts that were used on open knuckle half tons and all later model axles are a much better stronger design than the old (bigger) external style. The internal lockouts transfer the power from the shaft to the wheel hub through a set of internal splines in the wheel hub. The external style transfer the power through the bolts that hold the lockout to the wheel hub and have a problem with the bolts coming loose.
Tim |
Hmmm....never had that problem in over 30 years.Heard about it,though.
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 Last edited by va_tlc; 06-27-2007 at 08:26 AM. |
Peel it off.It`s just foil.
Yes, I like the 69 to 75 look, with the crome rim like va tlc's picture. I just got my $325.00 3/4 ton parts truck home (1977), for my 67 3/4 ton.I will use these axles for now because I need to get rid of these closed knuckle axles. But I will still look for the 3/4 ton 71 to 75 axles with disc brakes. thanks everybody.
