Old 06-27-2007, 08:10 PM   #1
84_4x4
84_4x4's Avatar
3 speed coulumn shift linkage
i have my linkage bars and my hardware to connect linkage to column but after looking i have no clue how my linkage arms connect to my transmission the po had put in a cheap floor shifter and i want it back on the column and i believe this is my last step after rebuilding the steering coulmn some pics or some helpful advice would be nice about connecting my linkage arms to the transmission itself this is a 71 3 speed
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 06-27-2007, 08:35 PM   #2
71tahoe
71tahoe's Avatar
Re: 3 speed coulumn shift linkage
I'm in the middle of changing the clutch in mine. Took tranny out last Sat. putting it back this Sat. The rod with the sharp bend attaches to the front shaft in the trans and the other longer one attaches to the back shaft. I believe the only way they will fit ands hift correctly is with the levers that bolt to the shaft pointing down.
Up on the column, I'm not sure because I didn't unhook them, but I think they bolt front and back the same as on the tranny. The back one should bolt through from the back and front from the front with the nuts attaching next to each other.
Pics can be had Saturday.
71tahoe is offline   Reply With Quote
