06-25-2007, 04:18 PM | #1 |
What shocks for bagged truck??
im just curious what shocks you guys are running w/bags... i have brand new shocks from CCP that came w/my 3-4 drop kit, but i think they are too long and wont compress all the way when the truck is dumped.. anybody have a certain shock that works well.. truck has bolt in bags front/rear and bolt in notch
edit: also has cpp shock relocate kit on rear thanks
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! Last edited by randomhero472; 06-25-2007 at 04:20 PM. |
06-25-2007, 04:40 PM | #2 |
Re: What shocks for bagged truck??
i'm using skyjacker shocks now on my fullsize but i'm gonna switch to fox shoxks w/ a resivoir. but on the c-10 i'm gonna run belltech nitro drop's. they nice and still but still give a good ride.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
06-26-2007, 09:41 AM | #3 |
i'll be running stock replacement shocks for a nissan frontier.....they are perfect for slamming your truck, and have 13in of travel for when you wanna raise your truck up all the way.
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife: 71 cab for sale in parts classifieds! 2004 black chevy 1500 "finish your beer, theres sober kids in india!" |
06-26-2007, 05:26 PM | #4 |
KYB's
06-26-2007, 10:32 PM | #5 |
I used stock Gabriel HD gas shocks on the back of my 68 when it was on the road before (rear bags only). Now that I've updated everything (& added front bags), I'm using Bilsteins.
06-27-2007, 01:25 AM | #6 |
i should have been more specific, what size/length of shock, and part #'s would also work.. thanks ttt
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-27-2007, 11:59 AM | #7 | |
I use direct replacement Bilsteins for the stock shocks up front & built my shock brackets to center the shock @ ride height. I used direct replacement Bilsteins for lowered 88~98 GM trucks in back. I fabricated a new upper shock bracket to mount them & also relocated the upper shock crossmember for proper shock travel @ ride height.
06-27-2007, 10:30 PM | #8 |
06-27-2007, 10:38 PM | #9 |
Specs: Compressed length? Extended length?
06-27-2007, 10:42 PM | #10 |
06-27-2007, 11:11 PM | #11 | |
I'm not saying it's not possible, but I cant imagine a shock having 16" of travel working in this type of application (uses close to stock or stock brackets/bracket locations). If I had the extended & compressed specs, as well as vehicle height (= shock length) @ ride height, the math would help explain. My front shocks (Bilsteins) are 15.5" extended; 10.5" fully compressed & are the correct front shock for 67-87's per their catalog. The Monroes I got from ART w/my a-arms were 14/10 & I'm not sure if they're for the 67-87 trucks. I figure optimum ride height is exactly the middle of shock travel which would be (for my example) 13"(Bils) or 12"(Monroes). That would allow for 2-2.5" or so of compression & extension or 5" total travel. 1" makes a big difference when trying to keep the shock from bottoming out within the limitations of the lower control arm & the shock mount on the frame. This is why I modified the shock mounts on both ends (ART a-arm lower & the upper frame mount).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-27-2007 at 11:13 PM. |
06-27-2007, 11:24 PM | #12 |
monroes for sure..cant beat $12 a shock considering they will go out quickly...
06-28-2007, 12:06 AM | #13 |
Why? If they're set-up properly w/the correct travel, they should live a normal service life.
06-28-2007, 12:43 AM | #14 | |
On all the bagged cars we have all run on monroes and we get about a 6xxx miles....and yes the shock are setup "right" so that they dont over extend or collasps. |
06-28-2007, 12:51 AM | #15 |
and if your system is quick you can forget about keeping shocks for long, the valves go out in them fairly fast.
06-28-2007, 01:07 AM | #16 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-28-2007 at 01:08 AM. |
06-28-2007, 01:30 AM | #17 |
sure
