Old 06-28-2007, 08:05 PM   #1
nwmod39
nwmod39's Avatar
how thick?
going to be having my work bend me up a c notch to use on my c-10 and was wondering what you guys might suggest to use for thickness. 1/4 or 3/16?
i was looking at some 3/16 and thought that it would be enough to do this with but would still like some expert advise,
thanks
steve
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 06-28-2007, 11:22 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: how thick?
I looked on www.***************** and see that they use 1/4" for the smaller notches and 3/16" plate for the larger ones. How big of a notch are you needing?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-29-2007, 06:55 PM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: how thick?
With a small C notch I would use 1/4" but with a step notch you could use 3/16".
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-30-2007, 12:46 AM   #4
Captainfab
60-66 Nut
Re: how thick?
I would say it depends on how it is designed. If it is designed properly you could use 3/16" for it. If you are pretty much doing it just like the ones you can buy, just stick with the material thickness they use. The cost/weight difference would be minimal.
Old 07-01-2007, 11:03 PM   #5
nwmod39
nwmod39's Avatar
Re: how thick?
thank you to all. it is going to be a basic c notch style that i will be welding in once i get power out to the garage. i was searching around at work the other day and found a good size piece of 1\4 inch that i can have and i will be making a blueprint to have the plasma table cut it out. then a couiple of 90 breaks and a weld in piece where the c notch cut is going to be and it will be done.
thanks for the input fellas.
steve
