Old 06-29-2007, 06:34 PM   #1
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Headlight conversion
Howdy ya'll, just have a quick question.
I just bought a set of (4) 5 3/4" headlights on fleabay and they don't fit my trim ring, so I'm looking for an alternative. I desire a new sytle bulb (H4 or high/low equivalent) in a 5 3/4" housing. Now, I know I shouldn't have gotten them off eBay, as they look cheap and don't fit the trim ring. I expect to clearance behind the bulb for any kit, but these ones are 1/8"-1/4" too small for my rings! Anyways, I know GMCPauls, LMC, Musclerodz, and some other site vendors also offer the converion kits and was wondering what experiences ya'll have had with them. Even the vendors can chime in. Thank you for the information, I no longer care about the prices.
lowrollin70gmc
P.S. I already coverted to relays for my headlights.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-29-2007, 07:06 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Headlight conversion
Not sure what our site vendors offer... I bet you'll find out soon enough, though!
What I can tell you is that major brand name headlamps (Bosch, Cibie, Hella...) will fit perfectly and are top quality. Not the cheapest, but worth the cost imho.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-30-2007, 04:34 PM   #3
lowrollin70gmc
Too many projects
I have been looking at Bosch, and I found a 5 3/4" setup, but now I can't refind it! Anyways, it's easy to find 7" (chevys), but 5 3/4" is a real pain for us GMC guys, I guess being better means these kind of headaches.
Andrew
Old 06-30-2007, 04:55 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
In no particular order...
http://www.danielsternlighting.com/p.../products.html
http://www.rallylights.com/hella/5.75_lo.asp
http://www.talbotco.com/e-code_lamps.htm
http://www.alfacybersite.com/ACSCibhl.html
http://www.classicgarage.com/accesso...headlamps.html
- Mike -
RIP El Jay
Old 06-30-2007, 07:35 PM   #5
lowrollin70gmc
Too many projects
You're my hero.
Andrew
Old 06-30-2007, 08:12 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've been using E-Codes in several vehicles since the early 1970s...
Glad I could help!
- Mike -
RIP El Jay
Old 07-01-2007, 04:27 AM   #7
GMC Jim
GMC Jim's Avatar
JC Whitney has 5 3/4" lamps with H-4 bulb, 60/55 watt part # SA9319P @ $15.99 each.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 07-01-2007, 02:58 PM   #8
GMCBubba
GMCBubba's Avatar
some of these are flat front lenses and some are convex. which of these looks best on our trucks?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 07-01-2007, 03:32 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
In the eye of the beholder...
I've had both (in different vehicles) and generally prefer convex lenses. For one thing, they're less noticeable -- and true E-codes are not street legal everywhere, though you're unlikely to be busted these days for headlamps.
- Mike -
RIP El Jay
Old 07-01-2007, 04:19 PM   #10
xshadow
What i was looking at was a headlight that you can change the small halogen light bulb like new cars today
xshadow is offline   Reply With Quote
Old 07-02-2007, 08:05 AM   #11
Orange
Licensed to Thrill!
Orange's Avatar
Originally Posted by Stocker View Post
Personal opinion - if you are going to spend the money - get some Hella's. They are worth it. And the best color of light IMO opinion is the Optilux (white) bulbs that they offer. They are cheap Chinese made bulb, not German, but they are very clean and give off good light. If you want the brightest, just plain light, for cheap, get you a set of CLEAR 100w Luks bulbs.
I used to own a 1994 Camaro - they had the crappiest factory headlights known to man. I spent hundreds on different setups and bulbs, so just go with me here.
That is what these are. They are "Sealed beam conversions". They look exactly the same, but they have a hole in the back basically. You can see it in the picture on rallylights.com
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 07-02-2007, 08:05 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hellas are excellent, as are Cibies -- which are a bit spendier than Hellas, but have a slightly different beam pattern, at least in the 7" size. Hellas are a bit narrower with more vertical light (high beam only; both have sharp horizontal cutoff on low beam, and flare up to the right for road signs) -- Cibies don't throw as much light upward, but have a bit wider beam which I prefer.
- Mike -
RIP El Jay
