Old 06-29-2007, 08:20 PM   #1
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
HELP-1970 1/2 ton rear axle shaft
I've recently invested a ton of money in the old truck and I'm running thin, so I need a cheap fix for the drivers side rear axle shaft. I went to change the brakes and found the rear seal was leaking so I pulled out the shaft and seal and noticed the seal looked almost new so I looked at the shaft and the bearing had worn a grove into it can it be welded and reground cheaply (is it OK to do this ?) or can I get a sleave to slip over it ? any thoughts ?
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 06-29-2007, 08:59 PM   #2
JimKshortstep4x4
Re: HELP-1970 1/2 ton rear axle shaft
I would suggest replacing the axle shaft. The groove will act as a notch and could lead to the axle breaking at that point. Used axles are relatively cheap and you should be able to find a good one as a lot of years will fit.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-29-2007, 09:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, it's probably a '70 only piece.
Old 06-29-2007, 09:17 PM   #4
72hotrod
72hotrod's Avatar
You can buy a sealed repair bearing that rides further outboard on the shaft, but I had a new one burn up before. And like JimK said, that groove does make the axle weak, but it will probably be OK until your boat comes in. If it leaks on the brakes they wont stop very good, though.Good luck.
72hotrod is offline   Reply With Quote
Old 06-30-2007, 08:20 AM   #5
jgrh64
jgrh64's Avatar
I ONLY have 198,000 mi on it , it's just getting broken in. Since this is a 70 only piece and coil springs has any one ever changed to a later model and converted to coils from leaf - is it easy or possible ?
Old 06-30-2007, 10:14 AM   #6
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
are you in cleveland tx or ohio? if your in tx, I have an axle shaft for a 70' 1/2 ton. you ccould come by and pick it up.
tommie is offline   Reply With Quote
Old 06-30-2007, 08:23 PM   #7
jgrh64
jgrh64's Avatar
Cleve OH, found out that advance auto parts can get them for me @ $86. ea. I just have to wait.
Old 06-30-2007, 08:24 PM   #8
Longhorn Man
did they ask you to remove and measure your shaft? There were 2 different lengths in 70.
Old 06-30-2007, 08:27 PM   #9
jgrh64
jgrh64's Avatar
I"ll make sure to do that before ordering, thanks for that info , mine was built in '69 if that makes any difference
Old 06-30-2007, 08:34 PM   #10
Longhorn Man
odds are it is the short one then, which, if it is, then it is the common piece 67 - early 70. But I've seen the wider ones used in early trucks... I shoulda checked the plant code in the VIN.
Old 06-30-2007, 08:36 PM   #11
nartkers
nartkers's Avatar
I just took both my axle shafts out. They are 6 bolt and I am converting to 5 bolt. They look good to me. If you cover shipping they are yours.
nartkers is offline   Reply With Quote
Old 06-30-2007, 08:40 PM   #12
jgrh64
jgrh64's Avatar
right now I'm about broke and work is between projects -I got a little crazy replacing parts (you know how that goes )but THANKS so much for the offer and all the advice given on this subject
Old 06-30-2007, 11:31 PM   #13
Longhorn Man
if the 5 lug shafts are thesame as the 6lug ones, then that would be the wide axle... the later axle
