Old 07-02-2007, 10:42 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
4X4 Alignment Questions
I recently rebuilt my D44 front with new balljoints, bearings, etc... along with polyurethane spring bushings. I also just purchased some new (to me) BFG 35x12.50 15s that are basically brand new. I was hoping to align the toe-in myself for the time being so that it can be driven around. Beings that it is a D44 solid axel I don't believe there are any caster or camber adjusments. I know that a good rule of thumb is to center the steering wheel and adjust the toe so that it is 1/8th inch toed in. My question is can I just take this measurement at the forward surface of the rim or will that allow for too much of a difference at the edge of the tires themselves? Any other tips for alligning 35s would be appreciated.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 07-02-2007, 05:17 PM   #2
Blazer1970
Blazer1970's Avatar
Re: 4X4 Alignment Questions
1/8" difference between the front and back of the wheel should be good. There are no adjustments for caster or camber on a stock axle, but there are aftermarket gizmos that allow you to adjust both. Unless the axle is bent you should be able to set the toe-in and you will be good to go.
Blazer1970 is offline   Reply With Quote
