Old 12-13-2002, 07:51 PM   #1
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
How much to cut?
one full coil is how much drop???
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 12-13-2002, 08:38 PM   #2
chevykid04
chevykid04's Avatar
and can i cut the back springs, cus i was told i cant???
Shane
1970 Chevy C10
Old 12-14-2002, 11:04 AM   #3
crazy longhorn
Fabricate till you "puke"
No, you cant cut the back springs, cause they have a pigtail on both ends.........also, avoid the temptation to heat them to drop(this is a serious no no!). On the front springs, I would cut 1 full ring, & the amount of drop will depend on what spring you have to start with. In my case, i started with the lightest NEW spring that i could get,cut 1 FULL ring off the bottom & have a 3" drop(after the springs settled in). If you are cutting used springs, you may not see this much drop, but the stockers will likely have 1/2-3/4" sag from all the yrs of use. To cut them, I tossed them upside down in a 5 gal bucket of water, lit the "smoke wrench" & cut the exposed end. done this way, the only part that could get "soft" was the first 1/2" of the end. Shorter springs also require shorter shocks,or shock relocators to run the stock lenght shock. I built the shock brackets for my longhorn, but you can pick up a set through Turner Enterprises for about $45. Good luck.....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-15-2002, 11:31 PM   #4
chevykid04
chevykid04's Avatar
yeah i would be cutting about a coil off my fronts, which are the original springs, just until i can afford new springs and spindles and everything , thanks for the info
Shane
1970 Chevy C10
Old 12-16-2002, 12:45 AM   #5
crazy longhorn
I have put about 12,000 mi on my cut springs, with no problems(they were gonna be a temorary deal). Good luck...crazy AL
Old 12-18-2002, 01:08 AM   #6
chevykid04
chevykid04's Avatar
yeah , i think they are gonna be temporary seriously, cus peice by peice i want everything to be new, and look new....
Shane
1970 Chevy C10
